DJI RC Controller Question
2968 11 2022-12-2
huntingidaho
I use my phone with the controller but I'm thinking about buying the DJI RC controller so I don't have to use my phone, is the controller a good option with the 5.5" screen? Would you recommend the controller? Thanks for your help.
2022-12-2
Mr. Strat
Flight distance : 4542854 ft
I use mine with a Mavic 2 Pro. Although it's alwo compatible with my Phantom 4 Pro V2, I like it better with the Mavic. You won't have a problem seeing the display in raw sunlight. It's very comfortable and you don't have wires dangling around.
2022-12-2
DJI Tony
Hi, huntingidaho. Thank you for your attention toward DJI products. DJI RC was rolled out to reduce consumer costs based on DJI RC-N1’s control with mobile phones. With DJI RC, users can fly their aircraft immediately after powering on, without connecting it to a mobile device and debugging it. In addition, the product design is more simplified in terms of systems, ports, and buttons, but without compromising its control experience. In terms of brightness, we compared the DJI RC with mobile devices on the market. When used outdoors, most mobile devices have a full-screen brightness of close to 600 nits in sunlight. While after the full-screen brightness of the DJI RC is manually adjusted to the highest brightness, the brightness can reach about 700 nits and be maintained for a long time, allowing you to have a better view of the image transmission, or shooting composition when you use it outdoors. It also offers cross-compatibility with other DJI drones like the DJI Mini 3 Pro, Mavic 3 Classic, Mavic 3, and DJI Air 2S. Hope this helps! Should you have further concerns, please reach back here at DJI Forum. Have a nice day.
2022-12-2
DAFlys
It's a really nice hassle free solution,     seems like a trivial thing not have to connect up the phone but it's really liberating.
2022-12-3
PatrickL
Belgium
DJI Tony Posted at 2022-12-2 20:19
I love the RC controller. I don't need third party systems but i would like to know if waypoints/controls would be to be add like drone control.
2023-1-3
DJI Tony
PatrickL Posted at 1-3 09:02
Hi, PatrickL. Thank you for your feedback. At present, we have not received any information regarding the addition of the Waypoint feature for the DJI Mini 3 Pro. But we will continue to gather customers' feedback and relay them to our DJI Developers for attention. Should you have further concerns, please reach back here at DJI Forum. Thank you, and have a nice day!
2023-1-4
coliwabl1
I must be missing something as I am unable to pair the DJI RC to my Mavic 3. I have attempted 3 x's without success. I have turned on the remote, then the drone, then tapped the pair button. It beeps for 30 seconds only to indicate that the two did not pair.
2023-2-13
DJI Tony
coliwabl1 Posted at 2-13 10:55
Hi there. Thanks for reaching out. We're sorry you're experiencing such issues. We recommend you try refreshing the firmware of your drone and remote controller through the DJI Assistant 2 (Consumer Drones Series). Once done, reattempt the linking process. If it still fails, kindly post a short video showing the connection process and the error. We will be waiting for your update. Have a nice day.
2023-2-16
djiuser_i5fysGyn7Zpo
Flight distance : 300082 ft
Avoid buying the smart contoller. Followed every possible suggestion of reseting it but to no avail.
Following the software update (latest one as of today 24-02-23) and one test flight, remote would not turn on. No LED lights, not charging or responding in any way.
This is a 400 dollar remote that is 5 months old and maybe saw 6 or so uses, completely unacceptable when you see the amount of people experiencing the same issue.
2023-2-24
PixelPro
Flight distance : 1205715 ft
It's  worth it in my opinion. Just keep in mind that you will loose a little bit of range
2023-2-24
Rolito
Flight distance : 107582 ft
I would like to know if the DJI RC will be OK to fly my Spark, if anybody has the experience.  Range and loss/gain of any features compared to original controller and an iPad?
2023-4-6
DJI Tony
Rolito Posted at 4-6 07:13
Hi, Rolito. Thanks for reaching you. Regretfully, the DJI RC is not compatible with the DJI Spark. It is currently only compatible with the DJI Mini 3, DJI Mini 3 Pro, DJI Mavic 3 Classic, DJI Mavic 3, and the DJI Air 2S. Therefore, it is not recommended to use it for the DJI Spark. Thanks for your understanding.
2023-4-9
