Avata camera is black
1440 6 2022-12-4
p.pucci.ch
Costa Rica
Hi.
My avata hast 25 min of flight.
Today when I started the aircraft gogles and remote, no image was displayed. It is black.
Any ideas on why this is happening?
Regards.
2022-12-4
DJI Tony
Hi, p.pucci.ch. Thank you for reaching out. We apologize for the inconvenience caused. We highly recommend refreshing the firmware of the devices using the DJI Assistant 2 (Consumer Drones Series).
Before starting the update, please ensure a stable internet connection and enough battery level.
Here are the steps on how to update the firmware of the goggles, remote controller, and aircraft:
1. On your computer, install the DJI Assistant 2 (Consumer Drones Series) from this link. Once installed, launch the DJI Assistant 2.
2. Connect the DJI Goggles 2/Remote Controller/Avata to the computer with a USB cable.
3. Power on the device.  After the software recognizes it, click the device name icon.
4. Select "Firmware Update" from the left-hand side and choose the option to "Update" or "Refresh" whichever is available.
Once done, restart the devices, relink, and check if the same issue persists. Kindly keep us updated. Thank you for your valued support.
2022-12-4
HDPS
Flight distance : 44957 ft
I have had this problem couple times, I am not sure if the problem is the goggles proximity sensor that sometimes does not work properly or the bad designed battery connector that can slip out very easy and cause bad contact. It comes back after re-booting
2022-12-4
Danisimo
Croatia
do you fix this problem?
2023-1-18
Saurav singh
Flight distance : 368655 ft
HI even i m facing the exact same issue bro u can see my thread also… have u found a fix?
2023-1-20
ro_walker
Brazil
this is very frustrating ....
2023-1-21
djiuser_zM0PDYENaOnq
Israel
After a slight hit on the wall, I see a black screen instead of the camera and all the telemetry works and you can see the other things. There is no external damage to the drone, I have a 1 gigabit log from Assistant 2 (*.DAT), which shows that there was an error, but I can't open it (or rather, I don't know how).
5 hours ago
