Sean-bumble-bee
Flight distance : 15997 ft
I too think that two controllers can NOT be linked to a Mavic 3, I think linking one controller displaces the other.
In addition, if you have flyaway cover then, for the cover to be valid the controller in use must be bound to the drone and the drone must be bound to the appropriate DJI account and ONLY one controller can be bound to the drone at any one time. If you wish to bind a second controller to the drone then you must FIRST unbind the first controller from the drone and then bind the second controller....... ad infinitum.
Incidentally, and for information only, you can use two controllers simultaneously with the M2P/Z but one is deemed the primary and the other the secondary, if commands are issued simultaneously on both controllers the primary takes precidence. The secondary has SIGNIFICANTLY reduced access to control menus and DOES NOT create logs in the phone attached to it.
You can also have two controllers permanently linked to the FPV but I think it only works with the standard controller AND the motion controller, I did not try two controllers of the same type. Only one controller can be used at anyone time. Switch both on and the first controller to connect to the drone is the controller in command.
