Where is the Serial Number for Mini 3 Pro Standard Remote ID?
22028 12 2022-12-5
3dbproductions
Flight distance : 1723471 ft
For us Part 107 Remote Pilots in the US that MUST register the DJI Mini 3 Pro for commercial use (regardless of weight), the registration process requests the Remote ID Serial Number.  After installing the firmware update that enables the M3P Standard Remote ID, where can I find that RID serial number?  PLEASE let's NOT let this thread devolve into a debate about the pros/cons of Remote ID or whether it needs to be registered or not.  I just want to know where the serial number for the M3P Standard Remote ID can be found.  Thanks!
2022-12-5
The Saint
Flight distance : 5902228 ft
if it exists, i think you can find it on the fly app.  can't remember exactly where.
i also think the drone itself is supposed to be marked or labeled correctly but depending on when you bought the drone or when it was build, it probably doesn't have the proper markings yet.
the portal asks for the details but i'm not sure the portal is ready to accept the details just yet.
2022-12-5
DJI Tony
Hi, 3dbproductions. Thanks for reaching out. For the DJI Mini 3 Pro, the Remote ID serial number is the same as the aircraft serial number and generally the same as the flight controller serial number. The serial number can be found on the battery compartment, packaging, the DJI Fly app (About page), and inside the “Available networks” of the WLAN of the drone.
Should you have further concerns, please reach back here at DJI Forum. Happy flying!
2022-12-5
3dbproductions
DJI Tony Posted at 12-5 20:56
Thanks Tony!
2022-12-5
The Saint
yeah that makes sense.  from the faa website:
"A unique identifier for the drone. Operators of a Standard Remote ID Drone may choose whether to use the drone's serial number or a session ID (an alternative form of identification discussed below that provides additional privacy to the operator) as the unique identifier;...."
2022-12-5
DJI Tony
You are most welcome! Hope you have a great time with your DJI drone. Have a nice day.
2022-12-7
Mobilehomer
Flight distance : 18135846 ft
With the drone connected, look under the "About" tab in the Camera view settings. It is there.
2022-12-7
djiuser_TVhIsGJ6AnDX
May I ask if the same is true for the Mavic 3 Classic, "Remote ID is the same as the serial number"?
2023-2-1
Bashy
Flight distance : 2354357 ft
djiuser_TVhIsGJ6AnDX Posted at 2-1 08:59
I would have thought so, yes.
2023-2-1
jollyroger8
Flight distance : 1076 ft
Bashy Posted at 2-1 20:04
What about for the Mavic 3? (Not the classic, or the mini, or Enterprise. This is for the original Mavic 3)
2023-2-25
Mobilehomer
The Remote ID is NOT the same as the craft Serial Number. It has a prefix set of numbers. You can find it in camera view/settings/about.
2023-2-25
djiuser_8AHkBVYu0OP6
Mobilehomer Posted at 2-25 09:58
Where? I cannot find that location?
2023-10-6
DJI Tony
djiuser_8AHkBVYu0OP6 Posted at 10-6 09:22
Hello there. If your drone has a 20-digit alphanumeric serial number (always prefixed with 1581F) the Remote ID serial number is the same as the aircraft serial number, and generally the same as the flight controller serial number. Have a great day.
2023-10-6
