"Temperature Low" - Not working
1056 7 2022-12-6
pablovee
New Zealand
Hi guys, I've never had this problem before even when recording in my own home.
DJI action 2 doesn't record anymore and keeps giving me the error of "Temperature Low. Only available in 1080p 30fps. Record higher quality videos after camera unit warms up."
I've even left the camera on for a few minutes to heat up a little bit. But it just doesn't work anymore. I've noticed that in the screen it also doesn't show battery levels and is blank as well as "0%" in the Mimo App even though the camera and battery unit are fully charged.
I've reset to factory settings multiple times. I've even let the camera cooldown and retry again. But doesn't record at all.
The photos work fine but recording doesn't cut it I've hardly used this unit and maybe 3-4 times since Sept 1 and I always store it in a safe compartment.
I live in New Zealand and is summer right now so it shouldn't give that error.
Any help would be appreciated
No battery status
No battery status
0% battery even though cahrged
Error message
Error message
2022-12-6
pablovee
New Zealand
When I factory reset and says to "tap to see battery level" still nothing
2022-12-6
pablovee
New Zealand
Also note, I've tried recording at the recommended settings it displays but still doesn't allow video recording
2022-12-6
DJI Wanda
Hello, there. Sorry for your inconvenience. We consulted with our engineers. Please submit an online repair request and send it back for repair. Here is the link:  https://www.dji.com/support?from=store_footer
2022-12-7
pablovee
New Zealand
DJI Wanda Posted at 12-7 00:05
Hi Wanda, thanks for the response. I've contacted support and are consulting with a specialist. I'll wait for their response and will check out the repair request if nothing else can be done
2022-12-7
pablovee
New Zealand
2022-12-7
DJI Wanda
pablovee Posted at 12-7 17:50
Understand. Should there be any questions, please feel free to talk.
2022-12-8
Droniax
My brand new, unused Action 2 will simply NOT record.....
It says 'ENVIRONMENT TEMPERATURE LOW, UNABLE TO RECORD".
I am in my heated home, temperature is 20 degrees Celsius.
I've tried all possible resolution settings, none of which will record anything.
Same message every single time.
I have never been able to record anything.
This is a total waste of money, I'm not even going to try and send it back for repair. Will buy the GOPRO system instead...... super disappointed in DJI.
2022-12-14
