What cheap external mic works with OA3?
12Next >
5076 61 2022-12-7
djiuser_Pkm8GQfiQXaO
Slovakia
Hi there.. Has anybody tried some external mics for oa3? I have ordere one wored USB-C mic from ali but it does not work on OA3.
2022-12-7
johansenfoto
Flight distance : 1173379 ft
Norway
There are some topics about this here if you look through all pages.
It is probably best to get a usb-c adapter and use any TRS mic.
BOYA BY-K4 is the adapter I use and it works great, but with a BOYA lav-mic it tend to be too loud so any cheap mic will do great.
2022-12-7
Bigplumbs
Flight distance : 620164 ft
johansenfoto Posted at 12-7 09:54
Many USB C Mics will not work. you need to seek out the other threads
2022-12-7
Fishycomics
I use the Aluratec wireless mic 100% works clearance over at best buy now I hears small rig works as well some others .
2022-12-7
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We highly recommend using the DJI Mic if you haven't purchased one. We also have the list of recommended external USB-C microphones and this is fully tested with the DJI Osmo Action 3.
1.DJI Mic
2. Soaiy:MK3
3. Flfine: FJ230
4. Latzz: A3
5. Lenovo: UM6S
6. Saramonic: U3A
Hope this helps. Thank you for your valued support.
2022-12-7
DaveInMoto
i use USB C Earphones from Huawei. I've cut the EAR part and the mic works very good and have good quality (i use it inside my helmet on my bike). The volume gain at 0db on the camera and is not clipping the audio. give it a try.
2022-12-9
lutzmix
Boya adapter BY-K4 usb-c to trs female work with cheap trs mic
the Boya BY-K2 is usbc to TRS male
2022-12-12
lutzmix
Andoer AD-M2
2022-12-12
lutzmix
with the Boya adapter you can use any TRS Microphone
2022-12-13
Slovakia
I have ordered lavalier wireless mic from ali.. I have found video on Youtube with guy trying it and it works great... waiting for delivery and will let you know
2022-12-13
lutzmix
SmallRigg  wave w1-c
output to camera is low
record time 20-30min than camera overheat
recording: camera accu drain up to 2,5%/min
distance: camera-mic. 30m worked well
2022-12-13
Iancraig10
A neat little directional mic that works via a usbC adapter is the Deity D4 mini. It’s a mini super cardioid mic that you can place on top of a frame, if you have one for the action and plug in a lavalier as well into the side of the D4 mini. That way, you can record anything in front while rejecting rear but pick your own voice up on the lav. Great for running around with the other half. Picks her up on the D4 and you on the lav.
Not for active stuff on bikes etc, but you get some great two way audio this way and still have just the lavalier if that’s all you want at other times.
2022-12-13
lutzmix
3,5 mm TRRS to usbc
cheap trrs mic or your Smartphone headset worked well
2022-12-19
lutzmix
trs Boya vs trrs No-name
wire noname is thicker
2022-12-19
Fishycomics
lutzmix Posted at 12-13 00:43
SmallRigg  wave w1-c
how long does hte small rig work on a single charge?
2022-12-19
lutzmix
Fishycomics Posted at 12-19 04:11
working time for the mic accu is 5-6h
mic shut down after 5 min disconectet to receiver
mic full charged in the box 1h
box full charged 2h
max operating time 30h
2022-12-19
Fishycomics
lutzmix Posted at 12-19 04:27
Thank you:    this may be my route to go. should have grabbed one when the sale was on at Amazon.
2022-12-19
lutzmix
trrs adapter & TRRS mic,
mit Käfig braucht man noch einen Winkeadapter
2022-12-28
Fishycomics
looks like a phone mic a trrs . not trs. so lets make sure we  tell people  that we use a TRRS
2022-12-28
lutzmix
it is a usbc to trrs and a trrs mic
the samsung adapter is also usbc to trrs
indoor : camera mic gain +6db is ok
trrs adapter 3bugs
trs adapter 10 or more
2022-12-28
lutzmix
TRRS ca 21gr
extern mic gain +10db
intern mic  noise redution on.
camera :4k 25fps rs+ wide clip-on cpl
2022-12-29
lutzmix
use a Boya usb-c trs cable and a cheap trs mic
output and sound are better than with a usbc trrs cable +trrs-mic!!!
2022-12-30
Sleepy0wl
lutzmix Posted at 12-30 01:04
I have ordered the Boya cable. Any recommends on trs mic?
Is it correct that we cannot have a mic and powerbank connected at the same time? Would a splitter work?
TIA
2022-12-30
Fishycomics
Sleepy0wl Posted at 12-30 11:47
DJI is not telling anyone if pass through works,
2022-12-30
johansenfoto
Norway
Fishycomics Posted at 12-30 11:57
In theory it should, just need someone to try it out making their own cable/adapter.
So if anyone have soldering equipment and know theese kind, go ahead. And could even 3D print an adapter it would fit in.
2022-12-30
Iancraig10
It might be a nice idea if DJI produced a proper adapter for their cameras. This hunting around for one that works is a bit silly. I use the Boya and it works well. Not always readily available here though.
2022-12-30
lutzmix
no splitter found that worked
mic  Andoer AD-M2 (example)
2022-12-30
Sleepy0wl
lutzmix Posted at 12-30 22:41
mic  Andoer AD-M2 (example)[Image]
Many thanks for that
2022-12-31
lutzmix
also ok Andoer AD-M1
Lavalier microphone with long cable. .
or any other 1-3€ mic
2022-12-31
pokiloh25
do anybody tried the j12 mic from ulanzi for the oa3 ?
2023-1-2
Fishycomics
Not yet,  thinking of small-rig as its swivals that way  when the Mode on is used, it will be out of the way.
2023-1-3
Urbsi
Hi there, i´ve bougt the Comica Vimo C3 wireless lav mic and Comica gave me a USB C to 3,5 mm cable, that fits perfectly in the mic receiver and in the OA3. But, the OA3 does not recognize the Comica mic.
So, I guess, that not every cable can be used? (It works fine withe the TRRS/TRS cable and the 3,5 mm/USB C adapter from apple.)
2023-2-9
Fishycomics
I have a Yi cable that does not work,  as well. but now a clearance sale on the  wireless one I have  alurateck
2023-2-9
Dirtymacho
India
Small Rig usb simor mic works fine. You can also try their usb-c wireless one but cost $89
2023-2-9
lutzmix
smallrig wave without deadcat
2023-2-10
Shawn Tew
Thailand
Ulanzi J12 wireless mich worked well on OA3.
2023-3-2
lutzmix
Ulanzi 2,4G hz wireless with voice recorder(not testet)
2023-3-2
Fishycomics
I wonder if they do a TRS style not usb C
2023-3-2
lutzmix
usbc to trs male from china is ok (aliexpress)
30cm
rs+ fov wide: iff you move to the left side you see the dead cat
2023-3-2
djiuser_bpa258lC5k8c
Poland
Hello, I have a question related to the microphone.  before I buy a wireless one in the future, I need a microphone for a motorcycle helmet.  How to shorten the cable in such as in the picture?  you need a maximum of 50 cm and there are 3 meters?  Cut and solder?  How do you solve this problem?  Thank you in advance for your help.
2023-3-2
12Next >
