DJI Paladin
Hi there, KerryG. Thank you for reaching out and we're sorry for the trouble.
First, connect the time code synchronizer to the USB-C port. Common time code synchronizers: Tentacle SYNC MKII OR EASYNC series. The Timecode sync device will connect with your phone through Bluetooth.
Timecode will be written into the sync device. After that, find "Timecode" in the system settings on your Osmo ACtion 3.
Connect the sync device to your camera and wait for the synchronization process to complete.
Next, identical resolution and FPS should be set as on other cameras then go back to the "Timecode" in system settings then attach the sync device to the camera and wait for it to process the synchronization then please check if the Osmo Action 3 will now be synchronized.
If the issue persists, please send us a video showing how you set up the Timecode on your device and also the error for us to check. Please keep us posted. Thank you. |
