Changing Wheel direction?
405 3 2022-12-11
MavGuido
Flight distance : 338793 ft
Hello Guys,
is there a way to change the direction of the RS2 wheel?
I use it for the Sony powerzoom lens function and for me it works better if the rotation is in the other way around.
Can i change that somewhere?
Thanks and regards :-)
2022-12-11
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out to DJI Forum. If you are referring to Front Dial, you may try the settings on the images below. Hope this helps. Thank you for your valued support.
2022-12-12
MavGuido
Thank you Paladin,
i try it and give a feedback.
Thanks and regards
2022-12-12
MavGuido
Hello Paladin,
with my RS2 and the Firmware Version of 01.05.00.20 there are no such option.
I only have instead on this position the reset button for resetting the dial settings.
Can you help me out with this please?
Thanks and regards.
2022-12-12
