DJI Mini 3 Error codes
4097 6 2022-12-12
TF10
Flight distance : 107730 ft
Dear All,
During a flight of my DJI Mini 3 Pro in September my drone suffered from a couple of problems (critically low battery?) and made a forced landing
I have been able to ascertain that two error codes relate to this event are
Code 800903
Code 30033
Can anyone tell me what these both mean and if they relate to my battery, should this battery be repaired / replaced?
Thanks
2022-12-12
JJB*
Flight distance : 12445630 ft
Hi,
A critical low battery is not a problem, just land before the battery gets into it critical value.
If you like upload your flightlog for this issue, use this > https://www.phantomhelp.com/LogViewer/Upload/
Post the uploaded link on here.
cheers
JJB
2022-12-12
DJI Tony
Hi there. Thank you for reaching out, and we're sorry to read about the errors you encountered. Error code 30033 prompts that the aircraft is landing with a critically low battery level warning, and 800903 means that the current power of the drone is less than the return power or is insufficient. In these cases, you are suggested to do RTH. These prompts are all about low battery. We recommend that you fully charge your batteries before your flights. Should you have further concerns, please reach back here at DJI Forum. Keep safe.
2022-12-13
djiuser_HPT4d19d41xi
I have nothing but problems with this DJI Mini 3. Cant fly anywhere, It asks me for documents to upload. Constant 40028 error with the gimble, there's no information for that error code..Just problems..
2023-2-14
Pablo Pascual
Hola buenas acabo de encender el dji mini 3 y me pone codigo 40028 del estabilizador pero funcionan perfectamente
2023-9-9
DJI Tony
Pablo Pascual Posted at 9-9 09:51
Hello there. Thank you for reaching out. Can you please try the steps below?
1. Make sure to remove the gimbal protector.
2. Check if the gimbal is stuck by a foreign object. If yes, please remove it.
3. Please restart the drone, and then let the drone on a level surface to calibrate again. Don't touch the gimbal during calibration.
4. Please make sure the firmware version is the latest or refresh the firmware version.
5. If the drone inserts the SD card, please remove the SD card to have a try.
6. Has the drone ever fallen or crashed before this problem occurred? If so, please send it back to us for testing.
*If the above factors are excluded and the calibration fails several times, please send it back to us for testing.
I hope this helps. Please reach back if you need further assistance. We appreciate your patience.
2023-9-10
djiuser_Cdsp7Pps3v8j
Hungary
A gimbal elakad,gömb-panoráma módban, ha egy kicsit fúj a szél (3 m/sec), a LOG tartalmazza a hibakódot.
Ez Drón hiba, vagy a Mini 3 jellemzője?
Error Code = 800117
3-14 21:56
