JJB*
Flight distance : 12401030 ft
Hi Zo..om,
Had a look at your flightlog.
In a RTH the OA is always ON, despite the Obstacle Avoidance Action setting = Off.
See my chart of your data.
Green line top chart is the RTH height setting of 131 meters.
Your Mini3Pro in RTH climbed to 131 and started to fly towards home. (see distance line and flat blue baro height line)
But the OA sensors had false readings, so it will climb and fly forward, stop, climb again, forward, stop etc ect.
Heading to home 268 degrees, time of the day "middle of the day", so sun was shining bit into the lens.
Nothing you can do about this, sensors too sensitive i guess.
See the manual for this.
a BUG? well....if in your situation the RTH was initiated bc of a disconnect...it would climb towards 500 meter.But how to change this behaviour? mayby after 3 * times up, forward and stop again disable the sensor and let the drone fly forward.
For sure if this is above 100 * meters of baro height.
* values arbitrary...
But what if after 3 times it flys against on obstacle....[ so make it a user option ]
EDIT
Did few RTH tests into the Sun, and 45 degrees left right offset to the sun.
At my RTH 30 meter it went towards home without climbing or stopping bc of obstacle sensing.
cheers
JJB
