sidtx
Flight distance : 266729 ft
Here's my experience as a new quad flyer.
I bought myself a P3 Standard for XMAS. Couldn't fly it for a couple of days due to weather.
In the down-time, I watched every video I could find. And I read the manual. There's a number of really good training videos on youtube. Everything from setup to your first flights.
There's also some good ones (Tom's Tech Time) on how to use the intelligent flight modes (follow me, POI, etc.).
I also practiced with the flight simulator. Although, for me, that didn't seem all that realistic.
For my first flight, I created a plan that consisted of this
1. Find a big open field (soccer complex near me worked well).
2. Memorize the starting steps (controller, quad, app, etc.)
3. Calibrated the compass
4. In the app, verified that beginner mode was on. Verified GPS Mode, Verified Safe-to-Fly was displayed in App. Verified home set. Started Video recording
5. With the drone facing away from me, start the motors, let idle for 10 seconds, just to get used to hearing the motors.
6. lift-off up to about 2 meters. Let drone stabilize for about 30 seconds.
7. Start gently moving controls. Up, down, forward, back. left, right, turn(spin) etc.
8. For first large movement, fly drone in a large rectangle, about 20m per side. After a couple of times round the box, do it in the other direction.
9. Now, move on to doing a similar pattern with circles.
10. Land. Shutdown. go home and watch the video.
That was it for my first outing. Just enough to get some experience with what the controls actually do.
On the second outing, I did much the same, except that I pressed the RTH button to see exactly what that would do.
Third outing, I turned off begginer mode, and expanded the flight envelope out to about 200m in all directions except up. for up, I stayed less than 30m.
After 2 weeks, I decided to start leaning ATTI mode. I read on this forum, that some users were having issues when drone unexpectedly went into ATTI mode.
I wanted to find out what happens, and practice flying in this mode should my GPS mode ever fail. This is a real eye-opener, especially with any wind or breeze.
It's not hard to control, just different, and makes you think more about your control actions. To date, I've spent about an hour practicing in ATTI mode.
If you start slow, and proceed with a plan, you should be fine. Confidence will grow with each flight. I'm having a blast right now! Have flown up to 80m altitude, and 400m horizontal. That's all I feel comfortable with right now. I probably won't go much further in height or distance, unless I go out to a rural location to fly. Even there, I feel the need to go way beyond VLOS.
Sid
