exter
Flight distance : 4085 ft
DJI Gamora Posted at 12-17 00:08
Hi, Exter. Thank you for reaching out. When saving the task library and executing tasks, the altitude is from barometer, and the altitude of the barometer is easily affected by various factors such as weather, resulting in errors. If you find that the altitude difference is too large during the use of the task library, it is recommended that you turn off the power after landing and try to take it off again. At the same time, it is recommended to fly at a height of more than 50 meters for timelapse photography. The higher the altitude, the smaller effect of the error of the barometer. Also, please fly the task and save the task under a strong GPS signal. We hope this helps. Thank you for your kind understanding. Nice shot, by the way.
Thanks all. Height was about 60 meters and GPS 22 satellites. Repeated with power off on.
Have made the day night transition more gradual and horizontal instead of diagonally across the bridge. Aligning the bridge of the 2 photos was a problem and made a gradully transistion impossible. Now it looks a lot better.
