Slow motion
1620 3 2015-8-15
remltr
4K 24 fps at 1/50 sec shutter speed does not like slow mo. Thought it was my computer. Tested 720p 60 fps at 1/160 sec shutter and smooth as butter and no jerkiness with craft yawing.
Of course overall quality does not compare.
Is this a function of the fps or the camera? Would a better camera at 24 fps 1/50 do a better job? Guess I could use my GoPro 4 Silver to answer that question.
Maybe this is just me educating myself on what works and what doesn't. Others are probably already aware of this and I am just catching up.
2015-8-15
Machoman
Flight distance : 1036959 ft
Austria
no the 24p is the problem!
normally you need 4k 60p for smooth yaw
however you can do a almost smooth yaw if you use ONLY gimbal yaw and fly only 4 directions
you have to set gimbal speed to 20 maximum
you have to assign C1 with gimbal pitch/yaw to be able to use gimbal yaw
2015-8-15
timax
I dont understand what your asking here remltr.
24p is far from slow mo. I personally would only consider 120p and above to be slow.
Are you shooting 24p and then trying to slow that down latter?
2015-8-15
remltr
timax Posted at 2015-8-16 14:43
24p is far from slow mo. I personally would only con ...
Yes that is what I was doing, shooting 50 fps and viewing at half speed.  It was just an exercise, not that I was shooting with the intent of outputting as slow mo.
Maybe the "talked about" next camera will have 1080p 120 fps
2015-8-16
