P3P has FW v1.3.20 but...
venomx15301
I took my P3P out for the first flight since I updated to v1.3.20.
The DJI Go iOS app says the P3P is running v1.3.20 but I had a warning that the bird needed updated?
Has anyone else seen this?
Went to the local park that has a ton of trees, power lines, and radio/cell antennas and could fly 4,500 away before I got a low/lost image warning. I guess that is good....
2015-8-15
venomx15301
Guess no one else is being told by the app that the bird needs updated when it already has been. hmmm
2015-8-16
sploodge
Flight distance : 809350 ft
When it says a firmware is needed, click it and it should say what needs updating.. Might just be the battery,...
2015-8-16
Skygod14
if it is the battery, you have to update the aircraft for as many times as you have batteries (obviously changing the battery after each update). so if you have 4 batteries then you need to update the aircraft 4 times as the batteries are intelligent batteries and the firmware will affect how the battery performs.
2015-8-17
venomx15301
No it says bird needs updated. On another forum there is a few dozen people with the same "bug".
2015-8-17
TomWolves
Flight distance : 110577 ft
venomx15301 Posted at 2015-8-17 01:37
Guess no one else is being told by the app that the bird needs updated when it already has been. hmm ...
I have the same issue, when I click on it,  says "go to Academy " ????  I did notice on the Phantom site the downloads they updated the APP, as it says 2015- 14-08 , well I had my Go App installed before this date. Or it could be just the IOS version is updated.
2015-8-17
venomx15301
TomWolves Posted at 2015-8-17 23:47
I have the same issue, when I click on it,  says "go to Academy " ????  I did notice on the Phanto ...
Yea the iOS DJI Go app updated but it did not fix that "bug".
2015-8-17
