Quick transfer on Mini 3 pro - "Connection failed"
10401 29 2022-12-18
mstram
I'm trying to get the quick transfer going with my  mini-pro 3 and a Samsung Galaxy A03S  / Android 12
I have DJI-Fly  v 1.9.0  running on the phone
When I press the "Switch" button  (on DJI Fly)  "Switch to QuickTransfer Mode",  I get a popup  with the name of my drone,  and "searching for devices".
It then says " Connection failed"
and :
1)goto profile - > settings - > quick transfer Band on
DJI Fly and make sure 2.4 ghz is enabled
I don't see any "quick transfer Band"   under profile -> settings
** I did set the speed to 2.4ghz  under the  "go fly" / settings / transmission
menu
2 Goto settings and make sure Wi-fI Assistant is diabled
  ---- which "settings" ?
       - Android phone  ?
           - Dji Fly "pulldown menu" / settings  ?
             Does the "swipe from top-settings-menu" even exist on the "phone"
                 version of DJI-FLy  ?
3 check the above and go to Setting to connect to wifi network manually
    Again which settings ?
        If I go to the phone / Settings /  Connections / Wifi  the  drone's  wifi name does not show up,
     (DJI-Mini3-Pro-7CAB)
      That name does show up under the  DJI-rc / settiings / Network & Internet / Wifi.
       But then it's asking for a password.
      Where is that password set ?
      And if I make that wifi  connection  (DJI - rc controller   - > Wifi - drone), what is that connection
    used for ?     (The quick transfer) ?
   Very confusing.
  And I consider myself pretty "computer literate"  (though admitedly a  newbie with Android / DJI
dji fly quick transfer
android wifi assistant
menu
       - Android phone  ?
2022-12-18
patiam
Flight distance : 1118740 ft
Please post Mini 3 Pro threads in the appropriate forum.
https://forum.dji.com/forum.php? ... peid&typeid=776
Mods, please move all Mini 3 Pro threads OUT of the Pro Systems forum to the Mavic>Mini 3 Pro forum where they belong. SNR is going to the dogs around here.
2022-12-18
DJI Tony
Hi there. Thank you for reaching out, and apologies for the inconvenience caused. Here are some troubleshooting steps you may try:
1. Ensure that the Wi-Fi, Bluetooth, and Location function are turned on in the mobile phone settings.
Note: In some Android mobile devices, the app Wi-Fi permission can be set separately. Check the Wi-Fi permission setting for the DJI Fly app and ensure that the Wi-Fi permission is allowed.
2. Try to use the Fixed 2.4 GHz function in the QuickTransfer Band. Go to the DJI Fly homepage>Profile>Settings >QuickTransfer Band>Fixed 2.4 GHz. If this does not show in your Settings, that means that the mobile device model does not support such a function. You may skip this step then.
3. Rename the aircraft. On the DJI Fly app, tap the three-dot menu Settings, and then go to About. Change the name of your aircraft.
4. Restart the mobile and the aircraft and try to use QuickTransfer again.
Kindly keep us updated. We appreciate your understanding and cooperation. Have a nice day.
2022-12-18
mstram
When I try to (Bluetooth) pair the drone from either the phone or the DJI RC controller,  I'm getting :
couldn't pair with dji because of an incorrect pin or passkey
2022-12-19
moontan
Flight distance : 504541 ft
India
mstram Posted at 12-19 01:24
Same here. It gives me a passkey to Bluetooth pair it, but where do I enter this key?
2022-12-28
Mobilehomer
Flight distance : 18135846 ft
RTFM!!! There is a "Quick Transfer" section, page 13.
2022-12-28
moontan
India
Mobilehomer Posted at 12-28 16:36
I have and followed all instructions but it still does not connect. Thanks for the very helpful advice, though. Really solved the issue!!
2022-12-28
primeshooter
Flight distance : 1433114 ft
Glad it is sorted.
2022-12-29
mstram
Lol   (your sarcasm detector is broken)
2022-12-29
Mobilehomer
moontan Posted at 12-28 21:58
The OP does not follow the manual.
2022-12-29
djiuser_jj9DCbYwp7MC
can you check the serial number of this stupid mini 3 pro if it is not a replica because i bought it from an online store by the serial number i have not opened the box yet i am sending you photos of the serial number and on the box it says made in malaysia is there a factory there and is there Russian language installed on the remote.
2022-12-29
djiuser_hd8rJi1e5nep
None of this solves the problem.  3 dots?  Where are there 3 dots anywhere in settings?
2023-3-25
djiuser_9vgDjgQXZJNe
Mauritius
Has anyone been able to resolve this? I am still unable to connect to the drone from my android phone (S10 and S21). The drone's wifi is not visible to any android device but it does work from iPhone and iPad. I expected more from a drone + RC that costs over $1000.
2023-4-2
fans05292d2d
Quick Transfer works with iPhone but NOT with my Android devices, Samsung Galaxy Z fold4 and Pixel 6a.
2023-4-12
RedRockDrones
Flight distance : 21362 ft
patiam Posted at 2022-12-18 14:52
https://forum.dji.com/forum.php?mod=forumdisplay&fid=129&filter=typeid&typeid=776
Why don't you try and help instead of derailing the conversation with "Get this thread out of here!!"  My God....
2023-5-1
RedRockDrones
I've the same issue...except my phone has a pop up before it shows the failed menu you listed above.  And it doesn't offer me an option to connect.  IN short, DJI's software is broken and they aren't doing a thing about it.
2023-5-1
RedRockDrones
DJI Tony Posted at 2022-12-18 19:58
Did you read anything the OP posted?  Or do you just copy/paste the same response to every question posted about Quick Transfer failure?  Is this what you call customer service?
Read what he wrote.  He obviously did those things.
And this ridiculous recommendation about changing the wi-fi name...is that some sort of parody or joke?  What is that even supposed to do?  Never in my years in computing has anyone ever suggested such a ridiculous action to try  and solve a connection issue.  FIx your hardware/software already.
2023-5-1
RedRockDrones
Mobilehomer Posted at 2022-12-28 16:36
N.S....it still doesn't work
2023-5-1
RedRockDrones
djiuser_9vgDjgQXZJNe Posted at 4-2 22:12
This is DJI...you expected wrong.  You bought into the Apple-esque product of the drone world.
2023-5-1
djiuser_bcCSCGjm7cPW
New Caledonia
Hello, same problem here, with a Samsung A51. After trying everything (rebooting, switching off data, manually entering mini 3 pro wifi settings, desinstalling and reinstalling the app,...), no success. My phone simply can't see the drone's wifi, where my laptop very quickly and successfully logs into it !!
Vive l'informatique !
2023-5-9
ChrisPro3
Flight distance : 843 ft
Same trouble here... on my ipad it works pretty well, but not on my trusty Blackberry (Android 8.1).  I once got it working, but man, that's kind of complicated:
I think it was:
- RC is off, drone is off
- mobile connection off (airplane mode)
- switch on the drone
- first switch on and pair Bluetooth (N.B.: I had to try a few times - I think it only worked when the paring code is sent from the drone, it appears on your phone screen, and not when the phone asks for typing in a PIN code, so watch out for that),
- then enable Wifi on the phone and connect to the drone
-  I think then it worked, but only then.  I had hoped it would work from then on normally but it doesn't. Only with this work around.
@Admin, maybe this helps with your fault finding.
2023-5-9
Bushcat69
Flight distance : 14701 ft
Switzerland
I resolved my "Connection Failed" issue by adding the DJI Fly app to the bypass list in Blokada, connected immediately after that and no issue since. I would have to assume the same would happen with any kind of ad-blocking app or VPN connection for that matter.
2023-5-14
GregP507
Flight distance : 404360 ft
I'm getting a message that my DJI Fly app can't Quick Connect because the drone is already connected to another device.  There is no other device.
2023-7-13
GregP507
fans05292d2d Posted at 4-12 16:33
Mine was working for over two weeks right out of the box, on my Samsung Galaxy S23, but then it just stopped working.  All it says is that the aircraft is already connected to another device.  There is no other device.
2023-7-13
GregP507
I don't think I need to change bands. it worked on the default setting for over 2 weeks, besides, I know the S23 is capable of using the 5 GHz band.
Changing the user name makes no sense to me either.  I'm afraid of really messing things up by changing it.
2023-7-15
djiuser_5y1sQPfwaRcA
New Caledonia
GregP507 Posted at 7-13 15:50
Bonjour avez vous trouvé une solution ?
J'ai un iphone 14 et impossible de faire le quick tranfert , pour la même raison !!
Have you find a solution ? I ve got an Iphone 14 and impossible to do the qucik transfet for the same reason
2023-9-24
JattyThomas0121
India
djiuser_5y1sQPfwaRcA Posted at 9-24 15:58
I searched on every forum on internet and eventually end up fixing this by changing the quick share visibility settings. https://thegeekpage.com/quick-sh ... g-on-samsung-phone/
2023-10-10
djiuser_sANBwSggHTHD
Turn off the phones VPN this worked for me
2023-11-13
djiuser_yEIwQlKSMQim
Flight distance : 467356 ft
Bushcat69 Posted at 5-14 11:02
My goodness, you are a GENIUS! I always try that when I have connection issues with websites, but this never hit me. Worked instantly. Thank you!
2023-11-15
Pifawe
Bulgaria
Hello all,
I am not sure if I have the same issue as you guys... but when I use Quick Transfer the connection always disconnects and it is really hard to transfer batch files. I thought that is from my drone, but I got a replacement and it is still the same issue ... more than 2 years. What I recently found is that the issue may be because of Google Photos.... when transfering files, google photos is trying to upload them imidiatly.
Try to stop Back up in google photos than force stop the app and try again. I was able to batch transfer all of my files. Probably only with stopping the Back up service will do the thing.
Please, say if this works for you as well.
4-15 03:13
