Can I install Firmware one more time?
580 1 2022-12-21
arve28
Flight distance : 168976 ft
Norway
Start to update firmware 01.00.0400 to Mini 3 Pro.
After a long time. It installet up to around 50%. Then the aircraft turned off. But not got on again. Turned aircraft on again. Installed tol66% then the aircraft turned of because of heating. Then the remotecontroll start updating the fly app to 1.9.0.
Try to update  on the controller-About. But it tells this is the last firmware.
Can I do this firmware oppdate on more time to be sure that everithing is ok.
2022-12-21
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. You may download the DJI Assistant 2 software on your computer and once you successfully install it on your PC or Mac, you will have an option to update/refresh the firmware for your aircraft and RC. Click the link below for you to download the correct version of the software. Hope this helps. Thank you.
https://www.dji.com/downloads/so ... sumer-drones-series
2022-12-21
