dii mini se
800 1 2022-12-28
Dagmaxander
Flight distance : 15823 ft
Poland
hola!!!!tengo el mini se y un iphone se 2020.Cuando inteno conectarlo me dice error de vinculacion, no me conecta el mando con la aeronave he probado a boorar la aplicacion y volver a descargarla actualizar el telefono pulsar el boton del mando y el de la aeronave a ver si se encuentran y nada......no se q hacer.Si alguien me pudiera dar una solucion se lo agradeceria por q estoy como loco de poder volar.
      gracias
2022-12-28
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please confirm if you still experience the said issue on your unit? Kindly please try to connect your Aircraft and RC to DJI Assistant 2 software and please update/refresh both devices then try again to link them to see if the issue persists. You may download the software using the link below. Please keep us posted. Thank you.
https://www.dji.com/downloads/so ... sumer-drones-series
2023-1-19
