The reason I ask is because DJI has yet to address the tilt function issue on the Naza M firm/software (no speed/gain control) so I was thinking if the Naza M would accept the Phantom 2 firmware I could run the Phantom Assistant to adjust the gain on the tilt. The video using the tilt on the Naza M is un-usable.
OR
Could I buy a Phanto Naza controller by it'self and replace my Naza M contoller on my rig?
Correct and yes I know you cannot use the Phantom Assistant for Naza M..... what I meant though was can you change/load the Phantom firmware onto a NAZA M v2 controller?.... THEN tune it using the Phantom Assistant software?... basically turn a Naza M into a Phantom controller?
Bummer..... still trying to find a fix for the lack of H3-3D gimbal tilt gain (speed) on the Naza M.... I will go back to hoping DJI engineers address this... :-(
