I can not pairing with RC after change transmission
501 10 2022-12-31
piyato
Flight distance : 15092 ft
Thailand
Hi
I have all updated with my dji mini se drone and dji fly app (with iPhone 14 pro max)
Yesterday I change transmission from auto to manual because many issue in my RC and close the drone It's can fly normally
Today after I'm open drone It's not pairing , I'm try push button drone 4 sec for new pairing and reinstall the dji fly app but nothing change
How Can I fix it , I just buy the drone only 1 month
I have video with this problem and a version of dji fly app
https://drive.google.com/drive/folders/1qNrNqKML2lY0RDeFxVEDrvpCJ-8yNV3j?usp=sharing
Thank you for your help
2022-12-31
fansabe45df9
New Zealand
She be broke now dude-dont ever change from auto to manual while flying-it will never connct again sorry-check this link out
https://forum.dji.com/forum.php? ... D775%26typeid%3D775
2022-12-31
DJI Wanda
Hello, there. Sorry for your inconvenience. May we know did you try refreshing the firmware of the aircraft and remote controller?
2023-1-1
piyato
Thailand
DJI Wanda Posted at 1-1 00:34
Hello  thank for answer
How can I do about refreshing dji mini se RC and aircraft ?
2023-1-1
piyato
Thailand
fansabe45df9 Posted at 2022-12-31 22:31
Thank you for answer
I just know , Many people have this issue I’m read all post but nobody can help ,
I think DJI should warning about change transmission or lock it
2023-1-1
fansabe45df9
New Zealand
Really??? Do you actually read what people are posting ? You must be a bot
2023-1-1
DJI Wanda
piyato Posted at 1-1 00:42
Normally, we will recommend users set the channel selection to Auto in the image transmission of the app to avoid high interference.
At present, the DJI Assistant 2 software downloaded from the official website cannot upgrade the DJI Mini 2 and DJI Mini SE directly, but the DJI Assistant 2 can be modified to achieve the upgrade. Please check the below steps:
a. Please download the DJI Assistant 2 (Consumer Drones Series) from the DJI Website;
https://www.dji.com/downloads/products/mini-se
b. Open the folder where the assistant software is located, and find the "DJI Engine" folder, find "defaultsettings.ini", then open it and change the "0" to "1". Please refer to the below path for Windows and Mac.
2023-1-1
piyato
Thailand
DJI Wanda Posted at 1-1 02:16
Thank for your help ,
I refresh firmware for both RC and aircraft
but it's not working , it's all same
2023-1-1
DJI Wanda
piyato Posted at 1-1 04:23
Thanks for your reply. You may also remove the SD card to try again. Make sure the firmware is the latest one on both the remote controller and the aircraft. If the issue persists after that, you are advised to send it back to our service center for testing.
You may search for the local authorized service centers here:
https://www.dji.com/service/repair/centers
2023-1-1
piyato
Thailand
DJI Wanda Posted at 1-1 04:49
Yes Im sure it’s last firmware both RC and aircraft and try with sd card and no sd card
I will send my drone to my service center soon
thank you for your help
2023-1-1
DJI Wanda
piyato Posted at 1-1 04:54
You are most welcome. Please let us know if you need our assistance.
2023-1-1
