DAFlys
Flight distance : 312090263 ft
DJI Diana Posted at 1-2 08:14
Hi, DAFlys. Sorry to hear about this. If the aircraft is idle for a long time or is interfered with by the magnetic field nearby, the sensor may be defective, and thus the DJI Fly app will prompt error messages. We suggest that you calibrate the IMU/compass. May I ask and confirm the following?
1. Was the aircraft flying in an environment with a relatively high temperature (greater than 30℃)?
Hi, I have re calibrated a number of times, as it prompts and cannot be flown until that happens. But after the calibration the Mini2 is very unstable, hovers badly and drops altitude when in motion.
No
2. Had the aircraft been turned on for a long time?
No.
3. Had the aircraft been subject to a large temperature difference? (For example, the aircraft flies from an outdoor area indoors in winter, or from an air-conditioned room to an outdoor area in summer.)
No
