Connecting the DJI RC to WiFi
19361 5 2023-1-3
FirstMedic
Flight distance : 120758 ft
Noobe inquiry:
The manuals for the RC and Mini 3 Pro indicate that there is a bunch of syncronization, activation, and etc. that happens before the initial flight.  Shouldn't the RC first be connected to the internet for all of this to happen?
Also, since I don't have a smart phone with data capabilities, I'm not sure how everything will work when I fly somewhere that has no WiFi hot-spots.
Any comments and/or suggestions?
2023-1-3
DAFlys
You can swipe down from the top of the screen to turn on wifi or press the cog to configure wifi.
You only need a data connection for geozone unlocks and maps. Although maps can now be downloaded and saved for offline use by doing to your profile and then off line maps.
2023-1-3
FirstMedic
DAFlys Posted at 1-3 02:07
I think I can do GeoZone unlocks at home, prior to going out to fly.
Also, am I correct in thinking that Bluetooth would not be necessary as it only connects the controller to a smart phone and is not used to control the drone?
2023-1-3
DAFlys
FirstMedic Posted at 1-3 03:25
Correct.  Bluetooth not required. In fact when you take off the controller turns off wifi and Bluetooth by default.
2023-1-3
DAFlys
You can unlock here and then sync the controller before you leave home.
https://fly-safe.dji.com/unlock/unlock-request/
2023-1-3
DJI Gamora
Hi, FirstMedic. Thank you for reaching out. You will only need the DJI RC to connect to the internet upon activation and updating the firmware so that you can pair the drone and the RC. After that, you'll be able to fly without an internet connection. Thank you for your support.
2023-1-3
