FRAP for Mavic 2 Pro with DJI GO 4.
1278 9 2023-1-3
kyalami
Flight distance : 17352513 ft
Sweden
I saw a link for the new FRAP from JJB, but that was for FLY APP. How can I find the FRAP for DJI GO 4 on an android phone and is that a different program? I have tried to e-mail JJB at jjbsoftware@gmail.com but it gets returned every time. I am interested in purchasing this software.
Got a new computer and lost the program.
Thanks.
     host gmail-smtp-in.l.google.com [172.253.122.27]
     SMTP error from remote mail server after end of data:
     550-5.7.1 [207.198.117.98] Messages missing a valid messageId header  are not
     550 5.7.1 accepted.  u10-20020a05620a454a00b006eb9975e33dsi18003226qkp.513 - gsmtp
Action: failed
Final-Recipient: rfc822;jjbsoftware@gmail.com
Status: 5.0.0
Remote-MTA: dns; gmail-smtp-in.l.google.com
Diagnostic-Code: smtp; 550-5.7.1 [207.198.117.98] Messages missing a valid  messageId header are not
2023-1-3
JJB*
Flight distance : 12260774 ft
Hiya,
Weird, i get a lot of mails at JJBsoftware@gmail.com.
FRAP is tailor made for DJI FlyApp drones, most of the new drones uses the FlyApp.
But GoApp logs will work too, guess not all the messages ect.
DownLoad FRAP link
https://mega.nz/file/oXBBHYjQ#c5 ... wgEzHX3hCN5I0FzV3j0
cheers
JJB
2023-1-3
kyalami
Sweden
JJB* Posted at 1-3 03:47
Hiya,
Weird, i get a lot of mails at .
Thanks very much for quick reply.
So this program for the FLY App also works for the GO 4 data?
2023-1-3
JJB*
kyalami Posted at 1-3 03:50
yes...
if you sent a log to my mail, i will check it for you
cheers
JJB
2023-1-3
kyalami
Sweden
JJB* Posted at 1-3 04:10
yes...
Ok thanks JJB. Appreciate that.
I would also like to use it by myself in order to learn.
So how can I donate to you?
2023-1-3
JJB*
kyalami Posted at 1-3 04:15
Install FRAP first, FRAP can be used for 15 days or 15 executions. (trialware)
In FRAP you can get a unlock code by making a donation of 25 euros.
cheers
JJB
2023-1-3
kyalami
Sweden
JJB* Posted at 1-3 04:18
OK, but where do a select this in the program?
2023-1-3
Sean-bumble-bee
Flight distance : 15997 ft
JJB I imagine you have done this or better but, and just in case.
When I was playing with my pilot's log book program it was initially written to work using specific field/column NUMBERS in the csv's of my flight logs.
From memory that worked perfectly well with the csv's from Go, Go4 and unencrypted Fly app logs i.e. column xyz was always speed, column abc was always height, column rdq was always 'such and such' etc. etc. but it DID NOT work with the csv's of encrypted Fly app logs since the columns moved.
I ended up having to get the program to look at column titles rather than column numbers and 'match up' column names to 'appropriate column numbers'.
No doubt my efforts are crude and inefficient but the program now scans correctly all my csv's.
2023-1-3
JJB*
Sean-bumble-bee Posted at 1-3 04:51
Hi Sean,
Thanks for the advice. FRAP works flawlessy...i have my own method of retrieving the correct data.
cheers
JJB
2023-1-3
Sean-bumble-bee
JJB* Posted at 1-3 05:14
Hi Sean,
I thought you might
2023-1-3
