Oskar_Pipa
Flight distance : 17989 ft
Brazil
DJI Gamora Posted at 1-3 18:47
Hi, Oskar_Pipa. Thank you for reaching out and we're sorry for the inconvenience. When a “Gimbal Stuck” warning is shown in the DJI Fly app (error code 40002), the gimbal may be stuck by debris (for example, the aircraft was powered on when it was folded, or the gimbal protector was not removed.). Please check whether there is debris on the gimbal. If yes, clean off them, restart the aircraft, and calibrate the gimbal. Or please try powering off the aircraft and move the gimbal gently at every angle with your hand, and check whether there is any debris in the gimbal. If not, power on the aircraft and calibrate the gimbal.
If the issue persists, you may consider sending the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at https://www.dji.com/support. We understand that this is not the answer that you look forward to, but this would be the best thing to do in this situation. In addition, warranty service can be claimed depending on the result of the Damage Assessment. Your kind understanding is appreciated and thank you for your continued support.
Hi, excellent support. Thanks for the quick response. I would like to calibrate the gimbal - maybe this is the way to solve the problem, because I don't see a mechanic or debris problem. Can you tell me how to calibrate? Is there a link I could follow? Thanks in advance. |
