ritch
Flight distance : 281490 ft
Czechia
Hello everyone! Many of us have this problem, including those who have FCC. I spent some time today looking into the issue and I found out what causes it. When I use the default color, the wireless video transmission runs at 50mbps without any drops as I would expect. However, after the latest update, when I switch to the 10-bit color mode, I start experiencing strong bitrate drops. This doesn't happen to everyone, and I know why. Many of you are filming with automatic ISO, and Avata adjusts the exposure as needed in this case, the problem doesn't occur. However, when I switch to manual ISO in this 10-bit color mode and just darken the image a bit, the bitrate of the wireless transmission starts to drop rapidly. If I darken the image a lot, the data flow can even drop to 4mbps at a distance of one meter from the drone. However, if I do this test with the image darkened in the basic color mode, the problem completely disappears and everything works as it should - 50mbps even at a distance of one kilometer without any drops. Of course, I did all of these tests while recording video to the SD card in the drone, so the drone was not running in power-saving mode. I also noticed that if I return the sharpness value from the original -2 to 0, the problem also disappears completely. To summarize, the video data transmission during filming with 10-bit color depth depends on the data flow of the video recording on the card, which I consider to be a bug because the wireless transmission should run at maximum data flow all the time, regardless of the data flow of the video recording. I therefore request DJI support to also test this bug and fix it in a future firmware update if possible. There are many of us who film videos with ND filters and in fully manual mode to get the maximum video quality. I also apologize for my English and I hope that ChatGTP translated this technical text into English as accurately as possible so that you understand my observations.
