Livestream to Youtube discussion and request
515 12 2023-1-4
Fishycomics
DJI the Youtube livestream is not working correctly, we (I) like to see a chat on the app open and the stream fixed, also since we have not made for kids, there is  what some have with creators called Monetization to be added,  I notice some are tagging Action 3 and are streaming, so can this be just an IOS issue  or catering to Droid more
the video will release soon  that said if any other person  has come across  that they see the   upcoming and can not stream do let all know, unless you like  chatting back and fourth  stuff...
FISH  helpful trying to be but yet we see it being  helped
In this video it is only the start to set up
In this video its the how you actually do livestream
coming in an hour or so
This is the Step By Step Livestream for Youtube How to correctly get it to work
1. DJI Mimi App ver 1.2.2 required . DJI Osmo Action camera fw 108.00.10 required. you are not with the  both  firmwares then it wil not work.
Step 1
Open App  (IOS App shown)
Step 2
App is searching for the connection
Step 3
Press Connect of your OA, if you have two chose the right one.
Step 4
Press Join
Step 5    program is connecting
Step 6. finishing up
Step 7
Swipe left until  the Modes go  to Livestream, if photo is the last one then you are not with the latest firmware.
Step 8
Choose Facebook or youtube, if t he first time see steps 21 -23.
Step 9 chosen youtube
Step 10
Pay close attention to your wifi and or  carrier  signal you must be connected or an error pops up as shown (sprints wifi is  off, causing the network error)
Step 11
Properly connected with LTE, Wifi etc
Step 12
Signed in to your  Router no spaces or special symbols. 2.4, 5G, Mobile hotspot
Step 13
Enter in your SSID,  and Password, example SSID 1234,   pasw12345
Step 14
If Mobile Hotspot is chosen  this is  locate your hotspot and enable it.
Step 15
Located on ISO swipe  to show up/down and   gray icon turns greem for hotspot
Step 16
Youtube you do not need but put a title to it
Step 17
Choose public, unlisted  private
Step 18
Choose HD or Smooth
Step 19
Chose a bitrate low or high
Step 20
Enable or disable save to copy only HD1080P is offered and after stream back to thevideo it defaults HD1080P30f
Step 21
if not signed in sign in and follow prompts
Step 22
Step 23
Step 24
ready to stream
Step 25
Step 26
If stream fails this is a messege,  saying make sure your SSID is correct and the network on
Step 27
You are not streaming until you complete Youtubes manage page.
Step 28
Mobile smartphone Open in a web browser Youtube and chose desktop  Apps do not work and only the older platform "Classic" works.
Step 29
Step 30
Locate the Live and start looking for Livestreaming to the right side
Step 31
Also located to the left
Step 32
find the control room
Step 33
You can correct and eidit if like, follow the steps 1, 2, live
Step 34
Hit preview
Step 35
Step 36
Almost there. you'll see the start stream icon
Step 37
step 38
You are now Officially Streaming
Step 39
You may finish up by closing down and congratulate yourself  you  got to Livestream.
As this should help  you out.  Any questions Ask.
FISH
2023-1-4
osmonauta
Hungary
Doesn't this streaming process require a SIM card AND a data plan?
I noticed that Mimo can connect either to the camera OR to your home router but not both. This is especially troublesome if you wanna download a new FW. First you have to connect Mimo to your router to download the FW, then you have to connect to the camera. Of course if you have a SIM card AND a data plan, things are OK, but companies usually don't spell out all the requirements.
2023-1-4
johansenfoto
Flight distance : 1173379 ft
Norway
Can you see the chat when streaming to youtube on your phone?
2023-1-4
Fishycomics
osmonauta Posted at 1-4 09:32
Problem solved   I wll share again the  actual vid in an hour. the problem is you need the youtube side  complete the start of the stream as I know
2023-1-4
Fishycomics
johansenfoto Posted at 1-4 12:05
to answer that question  no.  because the mimo app is open, if the app is    closed to go  to youtube the  mimo disconnects the action camera.
its not like gopro and gopro is way easier and more user friendly, and why I lean to that camera for livestream.
2023-1-4
johansenfoto
Norway
Fishycomics Posted at 1-4 12:31
I see, thank you for answering since I have only testet it with my gopro before
2023-1-4
Fishycomics
johansenfoto Posted at 1-4 12:33
GoPro switches to youtube and allows to see the  viewers and chat
DJI best  start working on this, its been this ways since Aprile of 2018
2023-1-4
johansenfoto
Norway
Fishycomics Posted at 1-4 13:00
True.
Wonder if it could be a way around?
2023-1-4
Fishycomics
johansenfoto Posted at 1-4 14:34
True.
two options I see:
1 mimo app, dji Action 3 and laptop
2  another phone, tablet  being mobile
you will need to access  the youtube app on mobile that is desktop  meaning  open the browsers and sign to youtube like you see via the desktop,  just not worth it
2023-1-4
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
HI Fishycomics
After setting up , action3 directly pushes livestream via the network to the platform. No need to keep the mimo open actually.
2023-1-5
Fishycomics
DJI-ytao Posted at 1-5 02:20
HI Fishycomics
If we watched the video, it does not work at all. if you have the resolution please do show us. am I the only one with the concern, hmm. (SMILES)
2023-1-5
johansenfoto
Norway
Maybe it only works with Android and not ios since Android have multitasking
2023-1-5
Fishycomics
that may just be it, catered to Android, less info from DJI offered  gets  issues like this brought up and maybe down the road  things will work hand and hand not an IOS friendly  camera  oil wells
2023-1-5
