Gabe R
Ive taken mine off using the hand land method several times with other peoples help before. I agree with everything sdharris said. Make sure to walk them thru whats going to happen several times before actually starting the motors. I would SUGGEST that they hold the legs ever so gently and not have it sitting in flat hands, when the motors start it could tip over if they aren't holding it perfectly flat that way.
Explain to them that you'll start it up and the props will do a small self test and then will idle, you'll then apply power and once they feel it pulling up they need to let go.
Practice it a few time on land, hand launch, hand catch, stop motors, start, hand launch, hand catch...should only take 2-4 times for the person to be comfortable doing it. |
