Base Station Center Point
2079 10 2023-1-5
MikeD31
Philippines
I just cant edit the base station center point settings. The Latitude, Longitude and Altitude are showing Multiple Values and it cannot be selected. Now I cant merge the file to my other Lidar Data without compromising the altitude. During the job,I paused the survey then changed the battery.
Please help and thanks.
Can't edit Lat, long and Alt
2023-1-5
GPSJamaica
Jamaica
Was there any guidance/solution for this? I'm having a similar issue - have one .obs file across several missions, some are allowing me to manipulate the coordinate, others are saying 'Multiple Values' and will not allow me access to adjust the coordinate. HELP!
2023-1-22
GPSJamaica Posted at 1-22 12:52
Hi there, if there are multiple base station values, the RTK base station data collected by L1 may be used instead of your own base station data. If you use your own obs file, you need to modify the obs file name according to the L1 data file name, and then put it in the L1 folder to replace the original RTB file.
2023-1-22
MikeD31
Philippines
DJI Mindy Posted at 1-22 23:34
Thank you for your reply, I reckon that I may have manually stopped the L1 data collecting rather pausing it automatically. I did not experience this issue after then. But I will have to re-survey the area that has multiple base station values.
2023-1-25
MikeD31 Posted at 1-25 18:40
Thanks for the update. We are sorry for the inconvenience. If there is anything else we can help you with, please feel free to contact us.
2023-1-28
dlcsureyor
Flight distance : 129354 ft
How is this done?
2023-9-19
Hi there, could you please tell us more details about the issue you encountered? Please elaborate on your inquiry so that we can better understand it.
2023-9-19
dlcsureyor
I’m trying to understand how to use the base station data out of the L1. Also, any insight on why this happens would be greatly appreciated. One of the flights that gave me the “multiple values” error was 6 hours from my office. Out of a total of 8 flights that day, only one was corrupted.
2023-9-20
dlcsureyor Posted at 9-20 14:36
As I explained above, if there are multiple base station values, the RTK base station data collected by L1 may be used rather than your own base station data. If you use your own obs file, you need to modify the obs file name according to the L1 data file name, and then put it in the L1 folder to replace the original RTB file. If you encounter any issues during this process, please provide us with more details or record a video showing the issue.
2023-9-21
DLCSurveyor
DJI Mindy Posted at 9-21 00:38
Im sorry, I should have provided more context. I am using the DRTK base station. I do not know what to do to correct this since I do not have my own .obs file.
2023-9-21
DJI Susan
DLCSurveyor Posted at 9-21 14:26
We will double confirm and get back to you.
2023-9-22
