Maps don't load on DJI Pilot PE
6171 20 2023-1-5
guilherme.nasci
Brazil
Dear all,
I have a Mavic 2 Pro used for mapping work. I used to plan my missions through PE Pilot, where I can plan all routes with a map view available in order to help me adjust the mapping area and flight duration. Since last week, the map view stopped loading the maps as I zoomed in on the survey area.
I checked the server configuration in the Pilot PE application and it asks for an address http://, username and password to access the mapbox server, I suppose. I would like to avoid having to import kml files to enter my mission plan into the smart controller. Could you help me?
Translated with www.DeepL.com/Translator (free version)
Regards,
Guilherme Nascimento
2023-1-5
DJI Susan
Hi there, we are sorry for any inconvenience caused. Please be advised that Mavic 2 Pro is not officially supported by DJI Pilot PE. Currently, the map service (Mapbox) is suspended, therefore, the map is not working on DJI Pilot PE.
In your case, if you need to create the KML file, you may try to use Google Earth to help to create it and import to the DJI Pilot PE, however, when using the Pilot PE after importing the KML file, the map may still not work.
Hope for your kind understanding.
2023-1-9
guilherme.nasci
Brazil
Hi,
Thank you for your answer. Is there an alternative procedure for planning a mapping flight using the DJI GO 4? We chose the PE pilot due to a difficulty in planning a route on GO 4. But if there is a way to plan operations on the GO 4, it would be better.
Regards,
Guilherme
2023-1-9
DJI Wanda
guilherme.nasci Posted at 1-9 04:36
Hi,
Regards,
Hello, there. Sorry for the inconvenience. DJI GO 4 App does not support the function. You may consider the suggestion above.
2023-1-10
djiuser_KnIgRkQwm2MZ
Flight distance : 525692 ft
I have the Magic 2 Zoom. Now I'm unable to view the map on Dji Pilot PE
2023-1-10
djiuser_KnIgRkQwm2MZ Posted at 1-10 17:30
Hi there, DJI Mavic 2 Zoom does not support DJI Pilot PE, you can refer to: https://www.dji.com/downloads/djiapp/dji-pilot-pe You can download and install DJI Go 4 to fly the Mavic 2 Zoom. https://www.dji.com/downloads/djiapp/dji-go-4
2023-1-10
bgrissman
Flight distance : 2093212 ft
Is there a timeline on when we can expect Mapbox functionally to be returned to the DJI Pilot PE app?
2023-1-11
DJI Wanda
bgrissman Posted at 1-11 14:32
Hello, there. We are sorry that DJI Pilot PE has suspended development and updates. It will not be compatible with more models in the future.
2023-1-12
bgrissman
DJI Wanda Posted at 1-12 04:08
It looks like the DJI Pilot app still works. Just not Pilot PE.
2023-1-12
DJI Wanda
bgrissman Posted at 1-12 04:56
We apologize for the inconvenience. We have confirmed that the iOS version for the DJI Pilot app is no longer being developed while the Android did not.
2023-1-12
djiuser_nyuofVNwQnmt
Albania
DJI Susan Posted at 1-9 01:33
Hi! I have a mavic 2 and smart controller.  I fly with the DJI PE but the map it doesn't work. Is there any problem during flying with the dji pe?
2023-4-7
djiuser_nyuofVNwQnmt Posted at 4-7 07:59
Hi there, DJI Mavic 2 does not support DJI Pilot PE, you can refer to: https://www.dji.com/downloads/djiapp/dji-pilot-pe You can fly your Mavic 2 with DJI Go 4. https://www.dji.com/downloads/djiapp/dji-go-4
2023-4-8
MorganBlack
Please disregard. I need to learn to read.
2023-4-20
MorganBlack Posted at 4-20 11:06
Hi there, may I ask if you encounter any issues? If there is anything we can help you with, please let us know.
2023-4-20
djiuser_SGOM9XrTFUud
Nigeria
Hi DJI,
I have a Mavic 2 pro and Mavic Air 2, what app can is use to do mapping?
2023-6-8
Nigeria
I have tried pix4 capture along with Ctr+DJI but it doesn't connect with the drone, ever requesting to give Ctr+DJI permissions to operate correctly which I have done severally.
2023-6-8
djiuser_SGOM9XrTFUud Posted at 6-8 07:38
Hi DJI,
Hi there, sorry to tell you that Mavic consumer series drones do not support the surveying and mapping function. DJI does not intend to add this function later.
The reason for this is because the surveying and mapping function has high requirements for the aircraft’s positioning system and camera lens. Currently, DJI  Mavic series drones cannot support such a professional function. If the user has professional mapping requirements, recommend that they purchase a DJI Enterprise product (such as Matrice 300 RTK/Phantom 4 RTK).
2023-6-9
rastim atiem
Indonesia
Hai! Saya memilikipantom 4 pro plus v2 dan pengontrol pintar. Saya terbang dengan DJI PE tetapi petanya tidak berfungsi. Apakah ada masalah
2-20 18:16
rastim atiem Posted at 2-20 18:16
Hi there, please note that Phantom 4 Pro V2.0 works with DJI GO 4. You can refer to: https://www.dji.com/hk-en/downloads/products/phantom-4-pro-v2
2-20 23:02
kmacman
Unfortunately I have just run into this problem as well.  I am using my Mavic 2 Enterprise, which is a drone intended for mapping with RTK.  Unfortunately the mapbox maps will not load.  Is there anything that can be done to resolve this issue?  I can sort of understand how the consumer Mavic 2 Pro would lose license, but for the Mavic 2 Enterprise it does not make sense because this drone is intended for mapping applications. Please help!!
4-9 07:24
kmacman Posted at 4-9 07:24
Hi there, may I ask about the current firmware version? Is it the latest version? Please also provide us with a picture to check the issue mentioned.
4-9 23:50
