Avata cam stopped working one fine morning
12Next >
5371 69 2023-1-6
Saurav singh
Flight distance : 368655 ft
Hi
I'll keep things short
I had been flying avata for past 40 days without any issues.
But due to a vaccation i was away for two weeks.
After which i was shocked to find out my avata is not showing any Video neither in the Goggles v2 or the dji fly app.
And from past 3 days i haved check everywhere to find no soulution till now.
I forgot to mention the drone is flying great with no issue i just have no video showing up to see anything
Ihave tried  the Following methods till now but still mo luck
1) tried login in and out of my dji fly app account. NOTHING
2) unbinded avata and rebinded it. NOTHING
3) reset camera parameters, dji goggles v2. NOITHING
4) removed sd cards in both goggles and avata . NOTHING
5) tried formatting sd cards in which to my surprise i m unable to format sd card via avata and evven while formatting internal storage of avata it says formating failed. Goggles are able to format both sd cards just fine.
6) one more thing which is weird i m unable to chnge any cam settings from my goggles 2 i see the option to change resolution but when i click it nothing happens and no the options are not greyed out.
Please help me out i have lost alot of sleep since last 3 days on this
2023-1-6
DJI Gamora
Hi, Saurav. Thank you for reaching out and we're sorry for the inconvenience. What are the current firmware versions of the devices? Please try refreshing their firmwares or update if outdated by installing the DJI Assistant 2 (Consumer Drones Series) from this link: https://www.dji.com/downloads/products/avata. After that try pairing them again and see if you'll have an image transmission. Please keep us posted. Thank you.
2023-1-7
Saurav singh
DJI Gamora Posted at 1-7 00:21
Hi ty for the promt reply
May god bless u with wisdom to help me on this problem i m in
I m currently on latest firmwares i have even down graded the firmwares tried the camera which was still not working then ihave installed the next firmware until i reach the latest firmware. But still i m facing the same issue. I did this with both dji fly app and the dji assistant 2 consumer drone series yet no luck.
I have noticed that dji avata has only one firmware listed in the assistant softwere so i have refreshed and installed it again also.. but still there is no vdo output in the goggles or dji fly app.
2023-1-7
celltx
Flight distance : 7399311 ft
Israel
Do you see the telemetry data in the Goggles: speed, height, distance, etc.?
2023-1-7
Saurav singh
celltx Posted at 1-7 01:41
Yes i do,
I see all the details except for the video.
2023-1-7
Saurav singh
I m still facing the no Video issue,,
2023-1-8
Saurav singh
I have also noticed that in the goggles 2 menu i m unable to change any cam settings. example changing the resolution from 4:3 to 16:9... its not greyed out but when i select and click the touchpad nothing changes it stays on 4:3. and funny enough sometimes it does change to 16:9 on random.
similarly other settings such as resolutions i m unable to change them.
i recently saw that my cam settings are on manual but when i click auto its does nothing it shows manual only.
2023-1-8
DJI Gamora
Saurav singh Posted at 1-7 01:08
Hi, Saurav. Thank you for the update and we're sorry that you're still experiencing the same issue. Would it be possible for you to provide us a video of operation? That would be much appreaciated. We will wait for your reply. Thank you.
2023-1-9
Saurav singh
DJI Gamora Posted at 1-9 17:05
https://youtu.be/KOvLK4Ws_gA
above link will show u the no video problem & how i m. Unable to change settings in the goggles
https://youtube.com/shorts/IskO_Cwuqxw?feature=share
The above video can show you that its flying great but i have no video feed
Pls view them and assist me i am at wits end now
2023-1-9
HDPS
Flight distance : 44957 ft
Saurav singh Posted at 1-8 04:54
strange, let us know if you find anything....on second video, would not show any video beacuse the goggles are blaked out, try put a piece tape on proximity sensor, goggles will think you are wearing it and will be on
2023-1-9
Saurav singh
HDPS Posted at 1-9 22:08
I m aware of that.
The issue is there is no video in the googgles even when i wearing them.
2023-1-10
Saurav singh
NEW UPDATE
After connecting to the pc i deleted two folders both in the avata internal storage & avata sd card & also in the dji goggles2. (DCIM & misc)
After which i m able to change different cam settings which previously i was not able to change.
But even after this I STILL HAVE A BLACK SCREEN IN the gogglev2 and dji fly app. i can see all the telemetry data but no video.
2023-1-10
DJI Gamora
Saurav singh Posted at 1-9 20:38
Hi, Saurav. Thank you for uploading the videos. We have forwarded the links to our relevant team for further checking. We'll get back to you once we receive feedback from them.  Your kind understanding is appreciated.
2023-1-11
Saurav singh
DJI Gamora Posted at 1-11 09:32
Ty so much i will be eagerly waiting for a reply I m sure u can understand this is very frustrating for me.
2023-1-11
Saurav singh
FOUND THIS video  https://youtu.be/8bnQx1lqK8c
Its all chineese but has subtitles below.
This guy faced the same issue as me but in dji mavic drone. He fixed his black screen issue by downgrading from the current firmware to the previous one which worked.
By doing so his drone was showing video again.
But to my badluck avata has only one firmware (v01.02.000)showing up in the dji assistant consumer series softwere so i m unable to DOWNGRADE the firmware on avata.
U can see the same in the follwing picture
Please look into this and let me downgrade avata so that i can fly again.
2023-1-11
Saurav singh
Any updates? Please i m holding on to the forums for my dear life here
2023-1-14
Danisimo
Croatia
The same issue ad you have , do you found solution?
2023-1-14
Saurav singh
Danisimo Posted at 1-14 15:15
no solution till now been over 10days , waiting for the Dji’s reply idk why we have to go through this when its not even our fault
2023-1-14
DJI Gamora
Saurav singh Posted at 1-11 22:41
Hi, Saurav. Thank you for patiently waiting and we're sorry for the delay. We now received feedback from our relevant team. Can you please confirm if the photo and video can be shot normally and can you view the picture? If you can, please Factory Reset the DJI FPV Goggles V2. Enter Setting>About>Reset all. If you can't take pictures at all and/or the issue persists after a factory reset, please consider sending the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at https://www.dji.com/support. We understand that this is not the answer that you look forward to, but this would be the best thing to do in this situation. In addition, warranty service can be claimed depending on the result of the Damage Assessment. Your kind understanding is appreciated and thank you for your continued support.
2023-1-15
DJI Gamora
Saurav singh Posted at 1-11 23:34
Hi, Saurav. We regret to inform you that a firmware downgrade or choosing a firmware to download is not possible since the previous firmware versions have been removed from our server. You can only upgrade it to the latest firmware version. Your understanding is highly appreciated.
2023-1-15
DJI Gamora
Hi, Danisimo. We're so sorry to read that you're experiencing the same issue. If you can take pictures and video and view the files, please Factory Reset the DJI FPV Goggles V2. Enter Setting>About>Reset all. If you can't take pictures at all and/or the issue persists after a factory reset, please consider sending the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. Thank you for your kind understanding and support.
2023-1-15
Saurav singh
DJI Gamora Posted at 1-15 07:25
No there is no video showing up even when i record or take a photo its black.
sending the product for repairs/assessment wont be possible currently as i am away with work.
& i have already tried factory reseting the googles v2 & even the camera parameters. nothing works.
my best bet is either u guys release new firmware update for the avata drone or let us downgrade so i can get the video transmission back.
I have seen many forums where the drone cam is showing black screen after firmware update but if u revert back to the previous firmware it solves the issue.
kindly assist me in hard resetting the  avata or pls release a new firmware which will solve the issue.
2023-1-15
Saurav singh
DJI Gamora Posted at 1-15 07:28
okay, then please a release a new firmware as it will solve many Users problem facing the black screen issue. its request.
today this is happening to a few people maybe it will affect every1 soon.
2023-1-15
Danisimo
Croatia
I already reset settings and also downgrage glasses and the controller firmware = not helped
When I connect regular dki fpv all work , avta no
Pictures and problem the same as on guy who init this topic
2023-1-16
Danisimo
Croatia
I record video -  https://www.youtube.com/watch?v=q46mNezEetM
I want to say: 0 - crashes , all firmare its updated for (drone , contoller and glasses ) also i try to downgrade glasses and controller , its not help to me.
2023-1-16
Saurav singh
Danisimo Posted at 1-16 11:26
wow same problem i have been facing since past two weeks.
this is definetley a firmware issue.....
2023-1-16
HDPS
Saurav singh Posted at 1-16 18:42
you can rollback the Firmware , google  wtf.com downgrade avata firmware, there is a Bardwell video on YouTube about it also
2023-1-16
Danisimo
Croatia
HDPS Posted at 1-16 20:37
can you attach links i not found solution for mac os
2023-1-17
DJI Gamora
Saurav singh Posted at 1-15 07:55
Hi, Saurav. Thank you for the reply. Unfortunately, upgrading might not resolve this issue. As per Danisimo's reply, he tried downgrading already but the issue persists. There might be a possibility that it is not a software issue that's why it is recommended to send it in for a proper diagnosis. I understand that you can't send it now as you are traveling, but feel free to create a repair case whenever you're ready. Thank you for your kind understanding.
2023-1-17
Danisimo
Croatia
What should i do , curently i live in Croatia (split) and i bouht  drone 2 month ago on dji site
2023-1-17
Danisimo
Croatia
DJI Gamora Posted at 1-17 05:54
Im not downgrade drone version cause , its locked  on last version you cannot downgrade avata
2023-1-17
HDPS
Danisimo Posted at 1-17 05:15
see links in the MORE....
2023-1-18
DJI Gamora
Danisimo Posted at 1-17 07:31
Hi, Danisimo. Thank you for the clarification. Please follow post #20 to isolate the issue. If the issue persists, I'm afraid that you may consider sending the unit in for a proper diagnosis.  You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at https://www.dji.com/support. We understand that this is not the answer that you look forward to, but this would be the best thing to do in this situation. In addition, warranty service can be claimed depending on the result of the Damage Assessment. Your kind understanding is appreciated and thank you for your continued support.
2023-1-18
Danisimo
Croatia
DJI Gamora Posted at 1-18 02:50
i should send only avata? and wat I need choose hear ?
2023-1-19
Saurav singh
I have found two other people on the forums facing the same exact black screen issue
Requesting the moderators/admin to provide a hotfix for this situation as this is clearly a software bug.
2023-1-20
ro_walker
Brazil
this is very frustrating ....
2023-1-21
Saurav singh
ro_walker Posted at 1-21 20:04
r u facing the black screen issue too??
2023-1-21
ro_walker
Brazil
Saurav singh Posted at 1-21 20:07
No I don't mate...
2023-1-21
Saurav singh
ro_walker Posted at 1-21 20:13
No I don't mate...
oh. then you dont have any idea how frustrating it is. i have spent so much money on this drone its just 40days old and it has no video in the camera.
And the dji support here is Useless they have not told us even one usefull method to get the video back when cleary its a Firmware bug and not a hardware issue.
2023-1-21
ro_walker
Brazil
Saurav singh Posted at 1-21 20:16
2023-1-21
12Next >
