DJI Mavic air 2
1369 4 2023-1-7
syed zeeshan
Pakistan
Hello everyone!
I have an issue: my Mavic Air 2 won't start. I can hear fans working, but there is no initialization process: no beeping sound, no led lights, no gimbal movement. Tried it with different batteries. Tried removing MicroSD card. Can't even connect to my Mac. I had luck and it turned on properly once out of 10 tries, I updated firmware immediately, but it lost connection to the RC and it won't turn on properly anymore.
I never crashed it, never used it in bad weather conditions. More than a month ago everything was fine. Did anyone have a similar issue?
Just Few Month back i change main board and its working properly.
https://youtu.be/HEQiABgtdmQ (Same Problem I facing)
2023-1-7
dddji
Hi
If you should have installed the firmware v01.01.1200, then unfortunately your drone is dead.
My MA2 is scrap too.
Customers have been scrapping their MA2 for days and DJI doesn't care, there's no reaction.
(....see also other forum posts about MA2 firmware)
2023-1-7
Yaros1
Flight distance : 19981112 ft
Hopefully DJI can fix this!!
2023-1-7
DJI Gamora
Hi, Syed Zeeshan. Thank you for reaching out and we're sorry for the inconvenience. May we ask if you were the one who changed the motherboard or did you send it to the facility? Please try to download the DJI Assistant 2 (Consumer Drones Series) to a Windows PC and check if it will be recognized. Here is the Download link: https://www.dji.com/downloads/products/mavic-air-2. If it's not turning on properly anymore using different batteries, I'm afraid that you may consider sending the unit in for a proper diagnosis. If you need assistance sending it to the facility, you may contact DJI support at https://www.dji.com/support. Thank you for your kind understanding and support.
2023-1-7
dddji
Hello Friends
Is there any news about the defective Mavic Air 2 firmware v01.01.1200?
Has anyone heard of DJI?
As I said a few posts ago, DJI lets us starve to death ............................ Cheekiness.
The entire DJI company is probably proactively in a coma at the moment.
Only incompetent chatter from the administrators, "...all customers are too stupid to install firmware"
To all admins: you mustfinally admit that DJI building ..., and not us customers!!!
There are now several dead MA2 drones again.
We must warn all Mavic Air 2 users to update their drones with destructive firmware v01.01.1200!
I would definitely not send the drone to DJI!
DJI wrecked our drones with unusable firmware, so DJI needs to fix that with working software too!
........... why should I do so much work for DJI's mistake now?
2023-1-8
