O3 no power
455 4 2023-1-7
sherifhafez
Flight distance : 27398 ft
United Arab Emirates
I got my O3 3 days ago, the unit is updated via USB to the latest firmware 01.02.0000
when I remove the USB and connect the AIR unit to the FC, the unit is not powered up even if I press the small pair switch
I also tried powering it from the FC 9V BEC and no luck, even with a 3S battery directly and no luck
am I missing on something here ?
i can still see it when connecting via USB
2023-1-7
dimitri666
check wiring looking at the doc of your FC. on some FC, dji connectors wiring is not standard
2023-1-9
Pete Watson
Flight distance : 31424 ft
What flight controller do you have?
2023-1-13
sherifhafez
dimitri666 Posted at 1-9 07:04
thanks, dear, I checked my 2nd o3 unit on the same FC and it is working
looks like my first O3 unit is faulty
2023-1-15
sherifhafez
Pete Watson Posted at 1-13 07:30
am using the MAMBA MK4 H743 V2 along with 55A/65A 128K Flight Control
2023-1-15
