I recently purchased a DJI Mini 3 Pro with the DJI RC. This adds to my DJI Mini 2 with N1.
The DJI RC has the same problem as the DJI N1 controller, in that the control for gimbal pitch/tilt is backwards, and there is no switch or option in software to reverse the direction of the control.
The DJI RC also has a finger dial on both left and the right of the control, and there is also no option to switch the dial from the left over to the right and vice versa, which is also a feature that would be most welcome.
We, your customers, need an option to change the direction of the tilt/pitch control for the camera gimbal.
The up/down gimbal tilt/pitch control on the DJI RC controller is backwards, at least for what is intuitive for many of us, and I noticed that a number of others have brought up this issue in the past, and yet there's been no action from DJI. It is utterly annoying, and I've ruined more than one shot due to the reverse-from-intuitive action of the tilt wheel.
For what it's worth I am also I am also a part 61 pilot (single engine land). In a manned aircraft, you PUSH the yoke to pitch down and PULL the yoke to pitch up. But with the gimbal wheel on the left, you have to PUSH with your finger to pitch UP. The opposite of what is intuitve for any pilot, and probably non-pilots as well.
This is also the case of a camera on a tripod: pushing the camera will cause it to tilt down, pulling causes it to tilt up. This is intuitive and obvious yet the DJI controllers tilt control is the opposite of this, and it is completely counterintuitive. All that is needed to help your customers, is to provide a switch in software to allow us to reverse the direction of the control.
All that is needed is a software switch to change direction of operation.
This is a significant problem, and also discussed here https://forum.dji.com/forum.php?mod=viewthread&tid=277682
Thank you for reading,
Andy
