360 PANO STICHED WRONG
2906 21 2023-1-9
Niknik
Flight distance : 1595640 ft
Greece
Hello DJI
360 Panos are stitched wrong same three photos on one side of the sphere
Here is an example of many:
2023-1-9
BladeZ
Flight distance : 1111969 ft
I have been having this problem too.
2023-1-9
Blériot53
Flight distance : 6188465 ft
That can happen when it's windy. Each time the drone turns to the next segment, there seems to be insufficient pause for the gimbal to settle before the shot is taken.
2023-1-9
Blériot53
BladeZ Posted at 1-9 07:17
2023-1-9
Niknik
Greece
Blériot53 Posted at 1-9 07:38
It was not windy at all. Also, the 25 photos are just fine captured. I use lightroom and the 360 pano auto stitch is done flauless. So the problem is the stitching the app does or the drone. All other Panos are done ok.
2023-1-9
Blériot53
Niknik Posted at 1-9 08:33
I think there should be more than 25 images
2023-1-9
Niknik
Greece
Blériot53 Posted at 1-9 09:08
360 PANO uses 25 captures and exports 100mb  360 pano
2023-1-9
Blériot53
Niknik Posted at 1-9 09:27
I see you're using the Mavic 3.
With the Mini3Pro, 35 images are composited into a finished image of 12.7 Mb, thus:
https://www.skypixel.com/photo360s/chateau-de-oudon
2023-1-9
DJI Tony
Hi, Niknik. Thank you for reaching out, and apologies for any inconvenience caused. The Panorama function was launched to resolve the smaller view of the existing camera. The principle of the Panorama function is to capture several photos with a certain overlap ratio and stitch them into a single photo for a wider view. Stitching is a process of searching for the edge parts on two images through an algorithm and overlapping the areas with the most proximate imaging effects to complete auto-stitching of the images. When the target is shot at a close distance, the coincidence degree between photos shot will become lower. As such, the software algorithm is unable to match the photo images, resulting in an error with the stitching position or a stitching error.
If a panoramic photo is poor in quality after stitching, it is often due to two possible reasons. The first is an excessively low overlap ratio for the photos that were shot. The second is a substantial change in the capturing environment, leading to a significant exposure difference in each photo.
Here are some recommendations you may try:
1. Please avoid capturing when there is a strong wind. When taking a panoramic shot, keep the aircraft still. Please try capturing in an environment that is not windy, and check if the stitching is still abnormal.
2. Try capturing in an environment without wind after gimbal and IMU calibration.
3. Try formatting the microSD card or using another microSD card. Before formatting the microSD card, please back up the data on it.
4. Refresh the firmware and try capturing again.
Kindly keep us updated. Thank you, and have a nice day.
2023-1-9
Labroides
Flight distance : 9991457 ft
I see you've had a couple of useless comments and suggestions already.
You've already addressed the possibility of wind being involved and  it wouldn't make that much difference at that distance from the subject  anyway.
The suggestions to  format the microSD card or refresh the firmware are ridiculous and won't do a thing to fix the issue.
Where do these nonsense ideas come from?
The built in stitching function is very basic and only good for simple easy stitches.
More complicated stitching requires dedicated stitching software to process the individual images.
Large areas of water and blue sky are always tricky for stitching because the software cannot find and identify a series of common points to match on adjacent images.
2023-1-9
Montfrooij
Flight distance : 2560453 ft
This is interesting to see.
I have had mixed results with the 'onboard' stitching.
Sometimes it worked much better than autopano, sometimes much worse.
2023-1-10
Geo_Drone
Flight distance : 2676129 ft
Romania
DJI stitching app is lower in control points than ICE or Lightroom for example...Because of this, when you have environment without strong contrast to make possible to identify control points that will be stitched, will go crazy.
This is especially valid when you get Pano or 360 with large water surfaces, as the upper photo does not present any points with high contrast in order to align with down and sides photos, making that ugly cut.
This is where you need to stitch it by hand, using manual points.
If you get clouds, will act like control points and you will not have issues in stitches with DJI internal app....
2023-1-10
Niknik
Greece
Geo_Drone Posted at 1-10 03:26
The thing is that using lightroom and photoshop it never stiches the final photo as DJIs is.  Lightroom does a nice job of stiching but it is the outside in and facebook does not recognise it as 360 either coming from lightroom or photoshop. I cant find any software that does it correctly.
2023-1-10
Geo_Drone
Romania
Niknik Posted at 1-10 03:46
That is the easy part... You need to inject EXIF metadata, is a free tool, or change in Properties of the Jpeg at camera: RICOH and camera model: RICOH THETA S
That will allow FB to "see" the JPG as a 360.
2023-1-10
Niknik
Greece
Geo_Drone Posted at 1-10 04:13
I tried that but still nothing
But the strange is that the original photo and lightroom are different stitched
Here are the stitched ones:
Original
Lightroom
2023-1-10
BladeZ
DJI Tony Posted at 1-9 20:30
I have been having this issue for quite a while now.  I had this issue happen again on 31DEC2022.  There was no wind.  My SD card was reformatted. And I have refreshed the FW on the Mavic 3 before the flight.
2023-1-10
ZeuS-FL
Flight distance : 5782297 ft
I have seen the same issue multiples time.
I and this is how the Mavic 3 stiching ruin a beautifull shot. Of corse, i do not know was ruin after uploaded, other wise i will re-take the shot mutiples times.
https://kuula.co/post/NjBMf
https://kuula.co/post/NjBMK
2023-1-10
DJI Tony
BladeZ Posted at 1-10 08:45
Hi, BladeZ. We are sorry you are going through the same concern. We sent you a PM to further help you with this issue. Kindly check at your earliest convenience. Thank you.
2023-1-10
Geo_Drone
Romania
Niknik Posted at 1-10 07:10
Bismostitch, ICE, PTGUI....try this ones.
2023-1-11
Niknik
Greece
Geo_Drone Posted at 1-11 05:21
I used ICE did it perfect. Afrer I opened with photoshop the original one and inserted the ice export on top and completed the remaining top with the color of the top and saved it and done. Perfect in facebook.
Thanks for Your suggestion.
2023-1-11
Geo_Drone
Romania
Niknik Posted at 1-11 09:52
Glad it helped.
Cheers.
2023-1-12
djiuser_YGv6dorSNMhZ
Flight distance : 904206 ft
Puerto Rico
It is SO rare that my 360 photos don't have stitching issues. The only reason I hold onto them is I hope I'll find a way to salvage them in the future through another software.
2023-10-19
