JohanTerink
Flight distance : 96972 ft
Hi DJI Tony,
thank you for your reply, I have checked the steps:
1) Windows 11, 32GB, DirectX12, RTX3060, everything is above the specs. The Flight Simulator and RM500 have worked properly before.
2) I bought a new Samsung cable, the issue still occurs.
3) Sticks calibrated, issue still occurs.
4) Tried on laptop, same issue
5) DirectX 12 is already installed and C++ Redistributable as well. Issue still occurs.
It worked last year, so I'm afraid it might be a hardware issue. Unfortunately, I only have the Avata and Mavic 3, which are incompatible with the RM500.
Should I sent the controller for a check? |
