New DJI RS 3 Mini Firmware Released (02/21/2023)
11259 21 2023-1-10
DJI Support
Flight distance : 2408 ft
Overview:
Date: 2023.02.21
Firmware: V01.02.00.00
Ronin App iOS: V1.6.2
Ronin App Android: V1.6.0
User Manual: V1.0
What’s New?
Fixed issue: some cameras could not connect to the DJI RS 3 Mini via Bluetooth Shutter in open environments.
Optimized gimbal stabilization performance.
Notes:
Make sure that the DJI Ronin app is the latest version when updating the firmware.
Update the firmware using the DJI Ronin app by connecting the DJI RS 3 Mini via Bluetooth.
If DJI RS 3 Mini has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
If the firmware update fails, restart DJI RS 3 Mini and retry.
Overview:
  • Date: 2023.01.10
  • Firmware: V01.01.00.00
  • Ronin App iOS: V1.6.0
  • Ronin App Android: V1.6.0
  • User Manual: V1.0
What’s New?
  • Optimized touchscreen sensitivity.
  • Optimized gimbal stabilization performance.
Notes:
  • Make sure that the DJI Ronin app is the latest version when updating the firmware.
  • Update the firmware using the DJI Ronin app by connecting the DJI RS 3 Mini via Bluetooth.
  • If DJI RS 3 Mini has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
  • If the firmware update fails, restart DJI RS 3 Mini and retry.
2023-1-10
Montfrooij
Flight distance : 2560453 ft
Thanks for the update!
2023-1-10
Luca Rubino
Flight distance : 711512 ft
Can't wait to get mine
2023-1-12
EYPhoto
The firmware failed and restarting results in it being stuck on backlight on but no screen or DJI logo pop up. Is there a way to hard reset?
Update: Screen stayed on backlight, but had to close the app and reopen. It was scary to have no indication on gimbal for reset and be stuck with a blank screen, but it can still connect bluetooth and update finished.
2023-1-12
fans02cb9d74
Please , when my lumix s5 will be compatible with the bluetooth of rs3 MINI ?
2023-1-19
RUD_fr
Hello DJI, why we can't have like Rs2 or Rs3 travel, panorama, timelipse etc on Rs3 mini small screen ? We need smartphone to do that ? it is more simple when it is integrated on your small screen. Perhaps you plan to integrate those tools in futur firmware for our new Rs3 Mini ?
2023-1-24
Vlk Josef
Czechia
Hello, please next firmware connect Dji RS 3 mini with IPHONE 14 PRO with bluetooth for recording video like DSLR!!! Or like OSMO 6 for tracking object!!! PLEASE, PLEASE, THANKS
2023-1-30
Rodrigo Maga
Peru
Hola, la pantalla del DJI Rs3 mini empezó a fallar, salen unas líneas en toda la pantalla, esto desaparece cuando la pantalla entra en modo suspensión. Por favor corregir, urgente
2023-2-16
Fred Fred Fred
Flight distance : 4512966 ft
Thank you Dji.
2023-2-21
Fred Fred Fred
Thanks Dji.
2023-2-21
Luca Rubino
"Optimized gimbal stabilization performance" Nice. I find it already really good. But if you optimized it, it's nice
2023-2-23
Webbie
Kuwait
Every time I open mobile apps its saying update new firmware I update it many times but still showing this msg, now there's a time connection failed and the "Updating firmware. View progress in DJI Ronin app" stuck on gimbal screen every time I open it?
2023-3-2
Mugrebaviera
Hello, i just bouth the dji ronin rs 3 mini and the firmware failed and whet im restarting the dji it show me a message that say quot;Updating firmaware. view progress in DJI ronin appquot; but it is stuck on that message and i cant conect the app to the ronin.  Is there a way to reset or do somthing about?
2023-3-2
Mugrebaviera
Webbie Posted at 3-2 02:07
Did you fix the problem?
2023-3-2
Webbie
Kuwait
Mugrebaviera Posted at 3-2 13:54
Yes now updated again its only the time the stuck notification on screen "updating firmware in DJI Ronin app" removed. Hopefully it will not ask again to update with the same version V01.02.00.00. I  hope some day they will a version for Z6 can connect to Bluetooth.
2023-3-5
coth
Russia
RUD_fr Posted at 1-24 12:32
It would also be good if trigger not only making full lock, but optionally switching to one of selected profiles, while pressed. So I can use M1 with PF and M2 with PTF, while pressed, for example.
2023-3-12
djiuser_fxODd2njyIP0
Brazil
Estou exatamente com o mesmo problema. Fica o display atualizando e da erro no aplicativo. Estou com o gimbal sem funcionar por esse motivo
2023-8-6
djiuser_dWhIiaJoKrDQ
I recently installed the focus motor to the RS3 and for some reason I can use the focus with the front dial with no problem but it won’t do anything when I try to control the aperture, iso it Shutter speed.
Currently connected to Canon R6 Mark II
2023-8-14
aero1199
Flight distance : 372192 ft
New Zealand
Can we please please please get support for the Canon R8 and Canon R10!  These are the perfect sized cameras for the RS 3 mini!
2023-8-14
IanG90
Greece
Webbie Posted at 3-5 21:01
Did you do anything or the notification disappeared by itself?
2023-10-26
djiuser_eacL6SxBIsBA
Lebanon
Mugrebaviera Posted at 2023-3-2 13:48
Hello friends, I faced a problem and I saw that some of you faced the same problem, which is that when I open the application, it asks me to update the device, and when the application was updated, the device screen remained on Updating firmware. The solution to this problem is simple. Go to the application and then to firmware. Then press on the firmware for 5 seconds and it will appear.  All old and new updates. Choose the old update and then wait for it to finish. Thus, you return to the old update and the Updating window on the device disappears.
2-10 06:45
Lebanon
If anybody need more information how i fix this problem send me watsap 0096181701763
2-10 06:48
