Ssayer
Flight distance : 629482 ft
Because of the season, I'm flying basically the same area all the time (that'll change come spring, but it is what it is right now). Most of the time, it's all good, but occasionally, say... 1 in 8 times, the compass will go a little wonky well into the flight and no longer line up with the drone. I take off and land at the same spot, so it isn't that. When it's off kilter, I have to be more careful because ot the toilet bowl effect (that was a real learning experience when I had my older Hubsan H501 drones). Just to make sure I'm being understood, here's a pic. If you look at the pic, you can see that while the camera is pointing at that red dot that I've drawn in, the compass shows the drone as facing about 75° off to the right. Every single time the compass goes wonky, it's always the same direction though the amount off can vary from say... 15° to 90°. Of course, this is regardless of whether I'm using DJI Fly or Litchi. Any thoughts?
