Pete Watson
Flight distance : 31424 ft
Pete Watson Posted at 1-14 01:28
Don't even know why I bother DJI Support are useless you obviously know nothing about the DJI FPV Drone. It can't be any clearer in my post above that there is an issue with the DJI Fly App. Support are just too lazy to report it. This is my 4th post on this I've had this drone over a year and repaired it so many times, and now i'm stuck because of this software issue.
It's nothing to do with the drone, if I put the old camera back in the drone there is no camera calibration issue, it's a DJI software issue!!!, I will try and find a third party way to calibrate it, if I can't I will strip it for parts and sell them on ebay, what a shame a perfectly good drone let down by zero support.
I've come to the conclusion that DJI support just cut and paste there reply's, it's a shame they don't have the technical knowledge to help.
Only way I could fix my issue was to remove the main usb-c board from the damaged second hand drone I bought off ebay and install it into my working drone, this is where the camera came from, it took me over an hour to remove and install in my other drone, calibrate camera is now gone and drone is working fine. Any damage to the camera on the Dji Fpv Drone and you have no choice but to change the main board and camera from the same drone, a camera from a different fpv drone will not work and need calibrating, there is no way of calibrating as the Dji Fly app does not work. |
