Obstacle Avoidance Question - DJI Mini 3 Pro
1964 5 2023-1-13
ROCKSTAR DRONE
Question, Can you still turn your drone with Obstacle Avoidance turned on using a DJI Mini 3 Pro? I know you can fly to left and/or right.. But wondering if you can still turn.. Any info would be greatly appreciated.
Thnx
Scott Legato
www.ScottLegato.com
2023-1-13
Prezzodrone
Flight distance : 8533 ft
Yes you can as long as your not near an object.
2023-1-13
ROCKSTAR DRONE
Prezzodrone Posted at 1-13 11:52
GREAT... Thnx
2023-1-13
Prezzodrone
If you set it to bypass it will automatically stear around an object.
2023-1-14
Drone Buddy
Flight distance : 280860 ft
Yes, you can turn but watch out for obstacles on the sides of the drone as it doens't have sensors on the sides for the obstacle avoiding system.
2023-2-14
DJI Gamora
Hi, Scott. Thank you for reaching out. Yes, you will still be able to turn the drone. In case the drone detected any obstacles, here's what will happen on each vision obstacle avoidance for Mini 3 Pro:
Bypass - The aircraft will automatically change and plan a new flight path to bypass the  obstacle if it detects an obstacle. If the obstacle cannot be bypassed, the aircraft will brake and hover in place.
Break - If sensing any obstacle in this mode, the aircraft will brake and hover in place.
Hope this helps. Thank you for your support.
2023-2-15
