DJI Gamora
Hi, N-huis. Thank you for reaching out and for uploading the photos. Please do a gimbal calibration and refresh the firmware of the drone. Below are the details on how to do them:
Gimbal Calibration:
Open DJI Go 4 App > Click Go Fly > ••• (3 dots on the upper right side) > Gimbal Settings > Gimbal Auto Calibration.
Notes:
1. Make sure to remove the gimbal protector.
2. Check if the gimbal is stuck by a foreign object. If yes, please remove it.
3. Please restart the drone, and then let the drone on a level surface to calibrate. Don't touch the gimbal during calibration.
4. Has the drone ever fallen or crashed before this problem occurred? If so, please send it back to us for testing.
Firmware Refresh:
DJI Assistant 2 Download Link: https://www.dji.com/downloads/products/mavic-air
1) Connect the aircraft or remote controller to the computer with a USB cable and ensure that the computer is connected to the internet.
2) Run DJI Assistant 2, click the Login button in the upper right corner, log into the DJI account, and select Mavic Air. Please ensure that the battery level is greater than 50%.
3) Click "Firmware Upgrade" on the left to select the latest firmware version.
4) Click REFRESH FIRMWARE/UPGRADE. During the update, make sure that the computer is connected to the internet at all times. Do not disconnect the USB cable or exit the DJI Assistant 2 software.
5) After the update is complete, restart the aircraft.
Hope this helps. Please keep us posted. Thank you for your support. |
