chiang__1
Flight distance : 68005 ft
Singapore
2wheeledphotog Posted at 1-19 05:15
I think the problem is that with the MC, the Avata doesn't really "dive." It just kinda descends mostly straight down with a slight forward tilt and not much else. Even if you fly in manual mode, the default setting for the Avata is to limit its attitude. I'm not sure what the limit is, but I seem to remember reading it was 30 degrees, so you can't even dive in manual mode without disabling the attitude limiter. And that's where you CAN get the Avata to truly dive (or roll), which I think is the move you're thinking of when you talk about following MTBers.
Yes! I shared this before to another person above, but if you look at this reels, at the 17th seconds, I was unable to dive down fast enough to catch up.
Luckily with a little editing, i manage to make the footage looks "deliberate"
https://www.instagram.com/p/CnUgKgYhCZm/
Maybe one day i will try using controller and Manual Mode, but for now, all i want and need to know is that i am not doing anything wrong, and there is nothing wrong with the drone itself (just for now, while learning) hehehe
Thank you for your reply |
