Can't Update Firmware
9160 19 2023-1-17
Caleb V
I currently have V01.00.0800 install on my Mavic 3 and I've tried to update to both V01.00.0900 and V01.00.1000 but It keeps failing.
In DJI Fly mobile app, it gets stuck at 67% like so:
And eventually shows "update failed" with error code 0x112105600002:
In DJI Assistant 2 (Consumer Drones Series) desktop app, it gets stuck at 82%, reboots about 3 times, and then shows "update failed" with two different error codes: 1-2-6 and 0x02a134 as you can see from this screenshot:
Both remote and aircraft are over 50% battery. I've tried rebooting and restarting everything. I've changed USB cables and ports. I've tried on my PC and Mac.
How can I update my drone?
2023-1-17
DJI Gamora
Hi Caleb. Thank you for reaching out and we're deeply sorry for the inconvenience. Since the aircraft is not updating on both software after the steps you provided, it is highly suggested to send it into our facility for diagnostic. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at https://www.dji.com/support. Your kind understanding is appreciated and thank you for your continued support.
2023-1-17
Caleb V
DJI Gamora Posted at 1-17 19:48
This sounds like a last resort. Can we not start with analizing logs from the drone or something? I'm not interested in paying repair service costs for something that can potentially be diagnosed, at a minimum, via support communication.
2023-1-18
Niknik
Flight distance : 1595640 ft
Greece
Try to refresh the existing firmware before installing the new one.
2023-1-18
Caleb V
Niknik Posted at 1-18 07:52
I have done that and it successfully refreshed the existing V01.00.0800 firmware. Which is another reason why I feel like sending it in isn't the solution. It's definitely just a software issue.
2023-1-18
BladeZ
Flight distance : 1111969 ft
Caleb V Posted at 1-18 07:54
Have you tried uninstalling and then reinstalling the DJI Assistant software?  I had this problem once and that the solution that worked for me.
2023-1-18
Caleb V
BladeZ Posted at 1-18 08:59
Just tried this, full uninstall, reboot, install of the latest, but same thing. When I connected the drone, I got this message again:
So I refreshed the current firmware and it was successful again. Then I tried updating to V01.00.1000 but it got stuck at 82% with the same error codes.
2023-1-18
DJI Gamora
Caleb V Posted at 1-18 07:31
Hi, Caleb. Thank you for the reply. Based on the detailed information that you have provided and especially on the error codes that you received, this issue cannot be resolved remotely. We apologize for the inconvenience.
2023-1-21
djiuser_X2WxXMzD2xbn
Flight distance : 256808 ft
I am having exactly the same problem
Was there ever a solution?
2023-7-22
It’s so annoying- really don’t want to have to send this back to be fixed. Please can you advise
2023-7-22
Caleb V
There was no solution for me other than sending it in. There was a hardward issue with the main board. Supposedly it would've been covered under warranty, however the drone was bought outside the U.S. (while on a shoot overseas) so they wouldn't cover it and it cost me $400.
2023-7-23
DJI Tony
djiuser_X2WxXMzD2xbn Posted at 7-22 15:31
Hello there, I'm sorry about the experience.  Can you please try these steps: First power off and reboot the remote controller and aircraft. Please make sure you're using the DJI Assistant 2 (Consumer Drones Series) if you're trying to upgrade it from your computer. You can also try updating the firmware from the Fly App. If that still fails, try using a different phone with the Fly app downloaded (For example, switch an iOS device to an Android device). Make sure you have a stable internet connection.
• Before updating, ensure that the battery level of the device (remote controller or aircraft) is above 50%.
• While updating, do not power off the aircraft or disconnect the USB cable. Otherwise, the update may fail.
• While updating, the device may automatically reboot several times. Do nothing before the update is completed to avoid affecting the normal updating process.
I hope this helps. Have a great day ahead.
2023-7-24
Turkey
Caleb V Posted at 7-23 12:57
Thanks Caleb, so annoying
I bought it just before a holiday I’m now on - did you fly yours with the previous firmware version. Just wondering if I risk it for the next two weeks and get it sorted when I get back home
2023-7-24
Turkey
DJI Tony Posted at 7-24 02:52
Let me try with the fly app later on today - I’ve tried all of your other suggestions with no job
2023-7-24
DJI Tony
djiuser_X2WxXMzD2xbn Posted at 7-24 05:12
Hi. I hope it works. Please keep us posted. Have a great day ahead.
2023-7-24
Turkey
Hi Tony - exactly the same problem
Let me know if there is anything more I can do or if I need to send it back
2023-7-25
Turkey
DJI Tony Posted at 7-24 19:21
Hi Tony
Exactly the same problem
Let me know if there is anything more I need to do, or if I need to send it to you
2023-7-25
DJI Tony
djiuser_X2WxXMzD2xbn Posted at 7-25 07:59
Hi Tony
Hi there. Seems like possible has already been tried. We advise sending the units to our facility for diagnosis. You may submit a repair request using the following link: https://repair.dji.com/gb/repair/index. Thank you for your patience and understanding. Have a great day ahead.
2023-7-25
djiuser_Q16jdhSM5Gia
Malaysia
Hi im from malaysia,  my dji mini 2 cannot update new fireware 2023. Stop at 40%. I have try update 3 batri have been use haha 40% stop now i cannot fly back tu my home pls help me tq
2023-8-20
DJI Paladin
Flight distance : 318 ft
djiuser_Q16jdhSM5Gia Posted at 8-20 00:39
Hi there. Thank you for reaching out and we do apologize for the trouble. In the latest version of the DJI Assistant 2 software, you can now update the firmware of your aircraft and remote controller using it. Just download and install the software using the link below to your computer and connect the aircraft using a USB cable to update the firmware. I will post a tutorial on how to update the firmware using the DJI Assistant 2 but this is for the DJI Mavic 2 series, the process is more likely the same. Hope this helps. Thank you.
DJI Assistant 2 software: https://www.dji.com/downloads/so ... sumer-drones-series
2023-8-31
