DJI Mini 3 Pro Motor Caps
4879 32 2023-1-17
Mini-G
Flight distance : 663304 ft
Hi all,
I was recently flying my Mini 3 Pro in sandy and dusty areas and was curious if any debris may have gotten into the motors.
Thankfully it was okay but it's made me wonder if these Dust Caps are a good idea.
I found this video on YouTube, and he address the concern I had about overheating, however, his tests were indoors.
Has anyone purchased these or have any thoughts about them, please share them below.
Thanks.
2023-1-17
DAFlys
Noooo,    think of the airflow through the motor you're blocking.
2023-1-18
DowntownRDB
Flight distance : 1722 ft
I tried some similar ones on the Mini 2 but after the flight the motors were much warmer than without them so I took them off and tossed them in the trash bin.  I think the motor coils didn't get enough wind through them to stay cool with the caps.
2023-1-18
KLRSKIR
Flight distance : 28368625 ft
As stated above, don't bother! Use a landing mat in those conditions or hand launch and land.
2023-1-18
Sean-bumble-bee
Flight distance : 15997 ft
Aside from what others have said, all the photos show the caps fitted to a Mavic Mini, NOT a Mini 3 pro. At 25$ Au it's an expensive gamble if they don't fit the Mini 3 Pro and/or jam the propellers.
2023-1-18
The Saint
Flight distance : 5902228 ft
there's probably a good reason why dji didn't put motor caps on the mini 3 pro.
2023-1-18
Prezzodrone
Flight distance : 8533 ft
Do i need these on the Mini 2?
2023-1-18
Mavic57pro2
Flight distance : 3772247 ft
They increase the rotating mass, not recommended in my opinion.
2023-1-18
Montfrooij
Flight distance : 2560453 ft
Prezzodrone Posted at 1-18 11:37
No. Don't use them. They can overheat the engines.
2023-1-19
Ken Storm
Flight distance : 178583 ft
Use them only if you have your drone on display and want to prevent dust entering the motors.
Otherwise, just let the motors cool naturally.
2023-1-19
Prezzodrone
Montfrooij Posted at 1-19 00:38
Why do they sell them then?
2023-1-19
Montfrooij
Prezzodrone Posted at 1-19 10:53
Because they can?
I don't know.
I don't put much on my drones.
DJI knows how to make them.
2023-1-19
Prezzodrone
Montfrooij Posted at 1-19 13:12
Because they can?
I don't know.
So i should stick to dji stuff?
2023-1-19
The Saint
Prezzodrone Posted at 1-19 13:55
yes you should stick to just dji stuff.  however, imho it's ok to consider other non-dji stuff from time to time.  just depends on what it is.
2023-1-19
Montfrooij
Well, just make sure you only buy what you really know you need.
Not what you think you need.
I have bought a lot of things for my first drone that I thought I would need, but....
I did not.
2023-1-20
Geo_Drone
Flight distance : 2676129 ft
Romania
Putting that caps you practically add a lot of torsion and angular force, preventing the propellers to change speed fast in order to respond to guts and other changes.
Will be toasted.
2023-1-20
Mavic57pro2
To make money !
2023-1-20
Prezzodrone
The Saint Posted at 1-19 15:01
Do you know any examples?
2023-1-25
Prezzodrone
Montfrooij Posted at 1-20 00:03
Thanks.  For the moment i think i stick with just the basics.
2023-1-25
Prezzodrone
Seems wrong if they arent safe
2023-1-25
The Saint
Prezzodrone Posted at 1-25 11:49
i suggest you continue to follow this forum closely.  from time to time, posters will talk about certain accessories that are "harmless" or they have found have no impact on the drone or maybe they were used with the previous drone version.
2023-1-25
Prezzodrone
The Saint Posted at 1-25 13:02
Thx babe. Just trying to understand what i really need.
These covers seemed like a good idea when flying in heavy rain.
2023-1-25
ThrasherG
Prezzodrone Posted at 1-25 13:07
Your opening another can of worms here, these drones are not waterproof and should NOT be flown in the rain (heavy or light!!).
Gary
2023-1-25
vladin
ThrasherG Posted at 1-25 14:53
Gary
Or maybe you can...
mavicpilots.com/threads/mini-3-pro-wet-suits-30-minutes-in-a-downpour.129019
2023-1-25
Tanasit
Flight distance : 145509 ft
I used  them before simply at first they look cool and perhaps help with dust protection but after several flights, I found out that I didn't really take off from dusty ground. I did test if the cover will cause the motor to overheat or get warmer by removing one of the covers and used the digital thermometer to check the temperature of the 2 motors (one with cover and one without)  and found no differences. Later concerning with the weight, I removed them.
The fitting is not the best because 1 of the 4 has slightly off centered hole and not seemed not to fit as others (or could be the motor case?).
People who gave reasons for not to use has their own idea and perhaps experience from other flying model which are reasonable but cool factor alone may negate those reasons for no solid proof to show.
2023-1-26
Montfrooij
Prezzodrone Posted at 1-25 11:55
That is the best way!
2023-1-26
Ken Storm
Heavy Rain!!! Under no circumstances should you fly in ANY rain.
Water and electronics do not mix. A sure fire way to ruin for aircraft.
2023-1-26
Mini-G
Tanasit Posted at 1-26 00:37
They look great!
Also what lanyard or strap are using on your RC Controller?
2023-1-26
Prezzodrone
Ken Storm Posted at 1-26 05:38
But dji make waterproof drones.
2023-1-26
Prezzodrone
Gary
Some of the dji drones are water proof.
2023-1-26
xenoxszis
Flight distance : 431322 ft
Philippines
Do you recommend it? I’m planning to buy one for the reason that in my previous flight, before taking off my drone from the ground, a kid suddenly showed up and accidentally kicked my drone, and one of my motors got drowned in the sand, causing it to stick up and preventing me from taking off. Luckily, I saved it by using an air duster and a little bit of patience.
2023-6-25
xenoxszis
Philippines
2023-6-25
xenoxszis
Philippines
2023-6-25
