No audio coming from the internal mic
864 6 2023-1-20
kript
Romania
Hey! So I got this osmo action fresh of a previous RMA of a different issue and everything seemed to be well until I checked the footage and none of them had sound. Just white noise.
I tried listening to the footage on the cam and the same result. I did a factory reset and nothing. The internal mic simply does not seem to work.
Here is a video of it:
https://www.youtube.com/shorts/ea2fnVOWz6E
Let me know if it's something that I can fix or if this needs to be RMA'd as well. Thanks a lot!
2023-1-20
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to reset the unit to factory settings first and then connect with DJI Mimo to check if there's a firmware update available? Update the firmware and check if the issue persists. Please keep us posted. Thank you.
2023-1-20
kript
Romania
DJI Paladin Posted at 1-20 20:49
Hello. Reset it and linked ot to dji mimo. No firmware updates, problem persists.
2023-1-21
Fishycomics
If you got the camera back from DJI, suggest getting back with the repair. and send it back so they can correctly repair it, then not inspecting  it . that be what we do.
2023-1-21
DJI Paladin
kript Posted at 1-21 02:23
Thank you for your response and we're deeply sorry for the trouble that this has caused. In this case, I'm afraid that you may consider sending the unit in for a proper diagnosis. You may contact our support team to start up a ticket at https://www.dji.com/support . Thank you for your kind and understanding.
2023-1-23
kript
Sweden
DJI Paladin Posted at 1-23 02:29
That's what I will do. Thanks!
2023-1-23
DJI Paladin
kript Posted at 1-23 12:22
You are most welcome. Please don't hesitate to reach us if you need any help. Thank you for your valued support.
2023-1-27
