DJI ASSISTANT 2 SENSOR CALIBRATION TROUBLE
4642 9 2023-1-21
djiuser_z9w4qN6SvQGV
Flight distance : 201220 ft
Brazil
Hi,
Recently got a warning on the DJIGO4 asking to recalibrate the back vision sensor.
Installed old DJI Assistant 2 V. 1.2.5.  I upgraded to the latest firmware W 01.00.0620, reset to factory settings. Try to calibrate but the calibration screen does not show up. After sometime the DJI Assistant ask to REBOOT THE AIRCRAFT. I do it, repeat all process and it get stuck in this step. Tried in a laptop and also in a desktop and it is not working.
What to do? Could you please give some advise?
2023-1-21
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we do apologize for the trouble. Can you please confirm if the aircraft experienced a hard landing? You may try to change the resolution of your screen for your reference you may take a look at this information. It is recommended to use a monitor with a size of 14 inches or more, and a curved screen is not supposed to be used. Set the display resolution to the recommended value ( usually 14 inches for 1366*768 or 1440*900; 17 inches for 1366*768 or 1280*720; 19 inches for 1366*768 or 1440*900; 22 inches for 1680) *1050 or 1920*1080; 24 inches for 1920*1080 or 1920*1200 ). I will post a tutorial video below for your reference. Please keep us posted. Thank you.
2023-1-21
MMori
Brazil
Hi,
No the drone never did a hard landing. It is not that often used.
I tried what the video showed, however the CALIBRATION PATTERN does not appear on the PC Screen.
Why the Assistant 2 does not reconize the drone and show up the calibration pattern?
What to do in this case?
2023-1-24
DJI Paladin
MMori Posted at 1-24 15:04
Hi,
Thank you for your response and we're deeply sorry for the trouble that this has caused. In this case, I'm afraid that you may consider sending the unit in for a proper diagnosis. You may contact our support team to start up a ticket at https://www.dji.com/support . Thank you for your kind and understanding.
2023-2-17
djiuser_KtWvhBIEjZPN
Zimbabwe
Hi
So I’ve been having a problem with my downward vision sensor. I’ve been trying to use the DJI assistant 2 but it doesn’t come with the calibration option and I don’t know why. If anyone has had the same problem please contact me. I’m using a DJI Mini 3
Kind regards.
2023-9-17
QuinnyE
Flight distance : 2021 ft
This is disgusting from DJI, I too have the same problem where I can't get the calibration prompt to go, my drone has never had a hard landing.
I feel DJI do this so you end up having to buy another drone.
Bunch of crooks
2023-11-11
DJI Tony
QuinnyE Posted at 11-11 23:18
Hi, QuinnyE. Sorry about the experience. The Mini 3 does not support vision calibration using DJI Assistant 2 software. May I know what issue are you experiencing with your aircraft? We are more than glad to help.
2023-11-12
DJI Tony
djiuser_KtWvhBIEjZPN Posted at 9-17 00:34
Hi
Hi there. Sorry about the inconvenience. The vision sensor calibration for Mini 3 using the DJI Assistant 2 is not supported. May I know what error message are you getting from your remote? Thank you for your patience.
2023-11-12
terrinecold
Hello,
I have the same problem as the opening post with my Mavic air (original). DJIGo4 asked to recalibrate the back vision sensor.  I can connect to the dji assistant 2 version 1.2.5 but when I try to calibrate I do not see any patterns.
Note that the software didn't seem to correctly detect my screen and asked for the size in inches which I supplied (27)
1-9 07:02
DJI Tony
terrinecold Posted at 1-9 07:02
Hello,
Hi, terrinecold. Sorry about the trouble. Please try closing the Assistant 2 software and then open and edit the set_screen_size.txt file in the DJIEngin catalog. Edit “unknown” + “Real screen size” and then Save. Note: There must be a space between the “unknown” and formal size. Re-launch the DJI Assistant 2 for calibration. If the issue persists, it means the screen cannot be supported. We recommend trying another screen or computer to conduct vision sensor calibration. We appreciate your patience.
1-9 22:08
