Sean-bumble-bee
Flight distance : 15997 ft
I suspect that occasionally, in my case 'hand tilt', causes some initial drift but that is only a suspicion, at other times I get pure vertical lift offs, my drift tends to be forward and left, i.e. diagonal.
That said, I have noticed that where the drone is placed on a slope the lift off is performed in two stages, it first levels itself then it actually lifts off, on a steepish slope care might be needed just incase this levelling cause the high side props to strike the ground.
With regards to the flightpath not matching your recollection, does that persist through out the replay or is limited to a portion of the flight?
I ask because some of my flight tracks in Airdata have had impossible bits at the start due to the fact that I often launch with insuffuicient GPS. The Airdata track show where it is thought the drone was and then, when the drone gets sufficient GPS, the track jumps to the correct position. I rarely look at the replays on the phone so don't know if they show the same quirk.
