My dji fpv cant fly in manual mode
1464 7 2023-1-23
mipper
Denmark
Hi i just got the dji fpv combo and i wanna fly it in manual mode but there seams to be a problem. It works switching into manual mode but when im in it it won't start i mean it wont go up in the air/start the propellers. And yes i have went into settings and switch custom mode into manual mode. pls reply i need help
2023-1-23
DJI Gamora
Hi, mipper. Thank you for reaching out and we're sorry for the inconvenience. Are you getting any error messages? What button are you using to start the motors? Can you please provide a video recording of the screen while switching to Manual mode using the remote controller and while turning on the motors?
2023-1-23
mipper
Denmark
im a bit confused how to start the motors im using the start/stop button but its not working
2023-1-24
mipper
Denmark
DJI Gamora Posted at 1-23 22:20
what button should i press
2023-1-24
DJI Gamora
mipper Posted at 1-24 07:17
Hi, mipper. Thank you for the reply. If you're starting the motors by clicking the Start/Stop button twice, check whether the interval between the two consecutive clicks is within 300 ms (0.3 seconds). If the interval between the two clicks is less than 300 ms, it is determined to be a double-click trigger. If this time limit is exceeded, a double-click will not be triggered. If the issue persists, please provide a video recording of the screen while switching to Manual mode using the remote controller and while turning on the motors. Thank you for your cooperation.
2023-1-25
FLY QUADS TV
Flight distance : 1175351 ft
South Korea
You have to set up in your goggles to fly in manual mode.
Goggles settings control m sport mode-》manual mode
2023-2-19
HughNorth
Flight distance : 1800305 ft
Im having the same issue. Any solution?
2024-9-3
DJI Diana
Flight distance : 2408 ft
HughNorth Posted at 9-3 13:01
Hi there,
thank you for reaching out.
May we confirm if you want to switch to manual mode and are experiencing issues with the switch?
Please keep us posted. Thank you.
2024-9-3
