Hello djiuser_d60S3T1QRSLu, Sorry for the inconvenience. Please try to troubleshoot as below,
1. Remove the SD card and restart the aircraft,
2. If the issue persists after restarting the aircraft, check whether the firmware is the latest version or not. 3. If not, please update to the latest version. And try again.
If this error message still occurs in the app, you are advised to send the drone back for further diagnosis. You could contact with our online support to create you a case manually or contact your dealer for help. Thanks. Here is the link: https://www.dji.com/support?from=store_footer
