Erreur etalonnage caméra Avata
1005 8 2023-1-26
DDC04
Flight distance : 4537457 ft
Réunion
Bonjour,
Je n ai plus aucun retour vidéo de mon Avata vers mes Goggles 2. L ecran est noir avec uniquement la télémétrie.
Un message d erreur apparaîtrait en précisant "erreur d etalonnage de la camera"
L appli DJI Fly me propose de télécharger les "données d etalonnage camera" mais le téléchargement ne demarre jamais.
J ai essayé de downgrader les firmwares Avata, goggles 2 et RC, cela ne change rien.
Le support DJI m'invite juste à renvoyer le drone mais je ne pourrai pas avant plusieurs semaines car je ne suis pas chez moi...
Connaissez vous ce problème de caméra ?
Merci
Bonne journée
Ps : pas de crash
2023-1-26
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi,
Have you tried with DJI Assistant ?
https://www.dji.com/en/avata/downloads
2023-1-26
DDC04
Réunion
Yes... to downgrade or upgrade firmwares. Doesn t work
2023-1-26
LV_Forestry
Latvia
DDC04 Posted at 1-26 08:22
Then its look like your unit is bricked. You will have better luck to DJI advice and send it to repair service.
2023-1-26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're deeply sorry for the trouble that this has caused. In this case, I'm afraid that you may consider sending the unit in for a proper diagnosis. You may contact our support team to start up a ticket at https://www.dji.com/support . Thank you for your kind and understanding.
2023-1-26
DDC04
LV_Forestry Posted at 1-26 08:27
I hope...
2023-1-26
Saurav singh
Flight distance : 368655 ft
I am facing the exact same issue from past 1 month
Dji should release a hot fix for this camera bug..
More and more people are facing this issue as we speak..
U can see my thread also
Requesting dji to release a ghotfix for this soon.
2023-1-26
DDC04
Saurav singh Posted at 1-26 21:44
Link for your post ?  Problem resolve ? Thanks
2023-1-27
fans6f364765
Flight distance : 406309 ft
Bonjour.
Même chose. Une solution ?
Merci
Good morning.
Same thing. A solution ?
THANKS
1-30 22:54
