aerdt
There are a lot of complaints about apparently "random app" crashes and I want to shed some light on how to set up your devices to prevent app crashes. Unfortunately, most modern mobile devices still lack the processing power for a real-time application like DJI Pilot of DJI GO, so, just like back in the days, where our generation had to free up memory to run certain games on a Commodore 64 or i386 computer, you will have to do the same or your app will inevitably crash. I am not saying that there might be coding issues or maybe memory leaks in the app, but this is the best that you can do to prevent app crashes from your end:
Enable airplane mode: This will prevent that, for example, an unexpected call will interrupt your piloting and also ensures that resource-intentive background apps update their status and additionally use resources. You will be surprised how much resources your phone/tablet uses, even in standby mode, if you have only one badly coded app running in the background. If in doubt, check your app store for a resource monitor.
Android: https://play.google.com/store/ap ... ft.sysmon&hl=en
iOS: http://appcrawlr.com/ios/system-status-activity-monitor-
Disable background activity of applications: Even, if an application is not open, it may run in the background, even after a complete reboot. For example, Facebook and WhatsApp are very resource-intensive in the background, even if you haven't opened them.
Android: http://www.tomsguide.com/faq/id- ... android-device.html
iOS: http://www.imore.com/how-control ... kground-app-refresh
Only use on devices with at least 2GB RAM and a fast, modern CPU: You won't be happy on an older, unsupported device, because you just don't have the resources to comfortably run the app. Sorry, but your mileage may vary, but just don't be surprised and all teary, if your app crashes. You cannot squeeze a Coke can through a pinhole.
But...but, you say: Why can I run any game without any lag? This surely uses more resources? No, it doesn't. Most of those resources are pre-loaded into memory, whereas DJI Pilot and DJI GO are real-time apps, that have not only to process real-time video, but also a whole bunch of telemetry and control data.
Hope this helps.
