FredBGG
Burgie Posted at 1-31 09:55
Another function that would be greatly appreciated would be the ability to adjust the parameters of the gyro pan/tilt speed in a better way than the rather small and way to difficult to finesse sliders that are there at present....maybe you could allow the focus knob on the righthand side handle to adjust the values (similar to the way that the handles work with the Ronin 4D when changing certain parameters)...I find that I am often changing these settings when using the gyro but also when using the joystick (I think that this is the only way to adjust the joystick settings which is also rather convoluted....basically you have to enable gyro then touch the icon, adjust the settings then disable the gyro..) I think it would make more sense if you could assign the focus knob to be pan speed with tilt speed activated by holding down the focus lock button and then adjusting the focus knob...way quicker!!...
I think the best option would be to allow more customization of the buttons so that users can customize the use of the handles. I for one would like two sets of options. One for shooting stills and one for shooting video.
It would be nice to have a quick menu where the user could insert parameters for quick access maybe using one of the handle trigger buttons. Click trigger to to bring up the list, turn the wheel to select, click trigger to activate and turn knob to change parameter. Would be great to have multiple menu lists so one could setup one for each type of use. 1 for stills, 1 for car mounted etc etc.
The hardware is great, but the system interface and menu could be refined more to really make this system fantastic. |
